Disable Hood Open Sensor
Old Oct 26, 2022 | 07:53 PM
ArmorOfG0d's Avatar
ArmorOfG0d
Default Disable Hood Open Sensor
Good day CL Team,
I got in a minor fender bender this evening. Seems to be mostly cosmetic damage, but the hood is slightly tweaked. Because of this, the hood won't latch down completely. It latches enough to catch so it won't fly up but not enough to engage the hood sensor. Therefore, I am getting the Open Hood warning on my dash. Honestly I will probably wait a bit to repair everything since the car seems to run fine. Is there any way to disable this hood sensor so I am no longer getting the warning on my dash? Any help would be appreciated. Thank you.
Old Oct 27, 2022 | 09:14 AM
AmyUD06's Avatar
AmyUD06
If you pull apart the hood latch, and unplug the wiring running in to it, and then jump that connector to short it, that should stop the hood warning notice.
Old Oct 28, 2022 | 09:55 AM
mandyfig's Avatar
mandyfig
Good advise! Or otherwise tape it up so it is always pushed down. Whatever works for you.
Old Oct 28, 2022 | 03:17 PM
ArmorOfG0d's Avatar
ArmorOfG0d
Thanks gentlemen. I'll have to look up a diagram of the latch, because it's currently covered and I have no way to see the under/backside of it without taking things apart. If it's a mechanical switch, then I'll probably opt to tape it since wires/electronics and myself don't mix very well, haha. I'll see if I can find a diagram later tonight to confirm what needs to be taped.
Old Oct 29, 2022 | 12:08 PM
ArmorOfG0d's Avatar
ArmorOfG0d
Can you elaborate a little more when you say 'it is always pushed down'?
I don't see a mechanical feature on the hood latch for the sensor. But maybe I just need to take everything apart...
I had trouble finding a diagram that was helpful. The best I could find was this one, which doesn't provide a lot of detail.
ItsJohnny
RX - 3rd Gen (2010-2015)
Jul 7, 2022 02:51 PM
DirtyD1985
GX - 1st Gen (2003-2009)
Mar 9, 2020 05:23 AM
calvin2376
Oct 19, 2018 01:52 PM
CAnima
Jun 17, 2015 09:47 AM
ExKoukiS14
Feb 14, 2012 11:00 AM
