Anomalies with IS250
It drives perfectly, until engine cooling fan kicks in and starts to heat up. I've been to mechanics and they've said that mechanically transmission is fine, and fan does it's job. But weird things start to happen when its hot. Acceleration starts to be laggy or too responsive, like something is going on with computer or smth. Also, when it happens, car always shuts it's engine off imidietelly I go from reverse to drive.
I don't get it, why it happens on the hot engine (or transmission). Anyone have a clue?
Lot of mechanics don't have a clue how to service sealed transmissions.
https://www.clublexus.com/forums/is-...ler-is350.html
Being a 250 the sluggish acceleration could easily be carbon build up on the intake valves.
So, with foot on the brake, engine warm, you put it in drive and continues to idle. However, if pulled from park to reverse it dies? Is that correct?
Or there are some who use the transmission as a brake when going forward and drop it into reverse. This action depending on the speed and RPM can kill the engine and is not recommended.
How many miles on it? When were the spark plugs changed? And how is it used? Is it doing a bunch of short trips?
Carbon buildup was my first guess but it was checked recently.
About stalling, not exactly. If you put from park to reverse it is all good. It stalls only in specific situation - when you go from Drive to Reverse and then to Drive. Or just from Reverse to Drive. I'm the only driver of the car and would never use transmission as a brake. It even sounds painful to hear that someone would do this. Everytime I change drive mode, I make sure car is fully stopped.
I did not change spark plugs since I bought the car, which was a year ago. It has 220k kilometers (136k miles). On short trips it drives like perfectly. Unless I drive trough city where are lots of traffic lights, jams, etc.
Bigger engines and trans back in the day but....
Have you had the battery and alternator tested? Cooling fans could be dropping voltage, perhaps start there.
If you don't know the plug condition, I would change them and have someone verify the carbon situation.
