Power Steering Issues/ light
Old Aug 31, 2022 | 05:59 PM
trdblackis's Avatar
trdblackis
Veteran: Army
Default Power Steering Issues/ light
I have a 2007 IS350 with 160k. My p/s light came on when backing up in my driveway. I turned it off and it went away, drove it the next day and it happened while driving. Its been a couple of months and it either does it when i turn the car on, hit a bump or just randomly while driving. I did mess with the module, but never unplugged it to try and change out my upstream o2 sensors. Any ideas before i buy a module or rack and pinion. Thank you.
Old Sep 1, 2022 | 01:40 PM
2013FSport's Avatar
2013FSport
I personally wouldn't jump to hardware replacement when it works intermittently. Disconnect the battery and Disconnect the controller under the battery and also the connections at the R&P.
Have some electrical contact cleaner and some dielectric grease for the assembly. The PS ECU has some tricky contacts. When you do the right action, the connector will come right off. It is not intuitive!!!
IIRC there is a small black tab you pop up with a pick, flip the bayonet and the connector will partially disengage. Then it escapes me, but you push something else to allow the bayonet to fully flip and detach.
Unless a battery lost acid there, I would start under the car first. JM2C
Old Nov 17, 2022 | 06:16 AM
trdblackis's Avatar
trdblackis
Veteran: Army
Fixed. Loose plug.
Old Nov 17, 2022 | 10:45 AM
2013FSport's Avatar
2013FSport
Originally Posted by trdblackis
Fixed. Loose plug.
Excellent.
Which one? Where at?
Old Nov 17, 2022 | 11:29 AM
trdblackis's Avatar
trdblackis
Veteran: Army
On the steering module. The plug on the passenger fender side.
MasAmiMas
RC - 1st Gen (2015-present)
Feb 4, 2025 03:40 PM
92 SC400
Mar 8, 2022 09:33 PM
needa
RX - 3rd Gen (2010-2015)
12
Feb 21, 2022 03:14 PM
snoopee220
Mar 28, 2009 01:40 PM
