Engine noise when cold start
Old Jul 15, 2022 | 04:08 PM
NismoPurpp's Avatar
NismoPurpp
1st Gear
Default Engine noise when cold start
VIDEO. 2012 IS 250. Noise has happened every day when I start up the car in the morning, or after a long time of no usage. It’s a ticking noise. Starts out loud like in the videos and then it gets quieter and sounds more like a slow random tick. Goes away after a like 5-10 minutes of driving the car. I got it diagnosed and the mechanic said he thinks it’s the fuel pump. I think it’s the water pump. Any ideas?
Old Jul 18, 2022 | 08:46 AM
MikeFig82's Avatar
MikeFig82
https://youtube.com/shorts/nghouXRusQ0?feature=share
That sounds rough.
Old Jul 19, 2022 | 05:11 PM
s3v3n's Avatar
s3v3n
Car engine sounds like it's gonna die soon. Looks like you need to do some serious cleaning on that engine.
Old Jul 20, 2022 | 08:44 PM
jgscott's Avatar
jgscott
More than a few 2GR's have had this. Its the Vacuum Pump.
Old Jul 21, 2022 | 05:16 PM
2013FSport's Avatar
2013FSport
^^^ what the whaaaa??? Vacuum.... hmmm....
Listening to that, the noise sounds to be half crank speed, which leads us to the top end. That sounds like stuck lifters not pumping up, which leads directly to show us inside the oil cap as I'm betting this machine missed several oil changes??
And it gets worse from sitting.
And it clears up when ran for a while.
All signs of bad oil, clogged feed ports, and/or low oil pressure.
Missed OCI's. As it clears up as the oil thins out.
Cheap oil.
That's my guess. Change the oil!
Old Jul 21, 2022 | 05:23 PM
s3v3n's Avatar
s3v3n
Cheap oil.
Every month for the next 6 consecutive months.
Old Jul 21, 2022 | 07:44 PM
jgscott's Avatar
jgscott
A few the GS350 in the 4th Gen had this problem. Also the Toyota Tacoma V6 crowd. It sounds like the same Vacuum pump 2GR problem.
https://www.google.com/search?q=Lexu...client=gws-wiz
ColonelTrt
RX - 4th Gen (2016-2022)
53
Nov 9, 2022 10:43 AM
GeeEss350
Apr 1, 2021 03:52 PM
brendanlim
May 24, 2008 03:53 AM
flunkie
Mar 10, 2007 08:11 PM
xsuperjoex
Dec 21, 2002 09:08 PM
