Need help please!!!
Old Feb 20, 2022 | 05:23 PM
toobetrue's Avatar
toobetrue
Smile Need help please!!!
Hi ~ any assistance is greatly appreciated. My car has been sitting for a while due to being ill, it's a 2009 IS 250 Went to drive it and key fob didn't work, I changed the battery key fob worked. Next time car would not start (turned over once) then went out. Called AAA and got a jump and was told my alternator was going out. Drove it that day and went out again in a week key fob would not open the door and the car would not start ~ heard some ticking around the battery but there was nothing I could do but lock the car manually. My question is if it was the alternator wouldn't I have gotten a warning beforehand? Also, should I have it towed to the dealer (the price was double) when I called the service dept. But after checking all that I could read on this forum, taking it to the dealer might not be required. I am a senior and just want to have it done correctly without being taken advantage of. Whatever advice I would appreciate it, I don't do anything without checking here first.
TIA
Old Feb 20, 2022 | 06:24 PM
Yamehoo's Avatar
Yamehoo
TIA
Sound like both battery and alternator are out. You should be able to check them with a multimeter to confirm.
Old Feb 20, 2022 | 07:04 PM
toobetrue's Avatar
toobetrue
Thanks....Would you recommend me taking it to the dealer or can most repair shops be okay?
Old Feb 22, 2022 | 03:35 PM
mandyfig's Avatar
mandyfig
Looks like the battery has died. Get a new battery and invest in a trickle charger and get quick disconnects installed as well (meaning it is plug and play). The majority of the time if a car is not a daily car, the battery dies. Lesson learned, the battery has to get some charging or else it will die a natural death. Trickle charger to the rescue! Good luck!
Old Feb 22, 2022 | 03:50 PM
toobetrue's Avatar
toobetrue
Thanks Mandyfig.....this is exactly what I will try. Thanks again
Capirato
GX - 2nd Gen (2010-2023)
216
Jan 25, 2025 02:04 PM
loydd24
Jun 20, 2023 09:59 AM
Juug2kBoy
Feb 26, 2020 02:39 PM
Cdd
13
Oct 9, 2019 11:21 PM
LexusK
Mar 3, 2009 10:50 PM
