i’m new here to the forum. i need help with a wheel and tire set up for a perfect flush fitment . i want a meaty set up …. and a perfect offset front and rear
I am using stock wheels and installed spacers in the Rear, 1" and the wheels in the rear appear flushed. I did not bother with the front because it appears almost flush.
I think my fitment is pretty good. My wheels are Wedssport TC105X and the specs are 18x8.5 +32 and 18x9.5 +35. And the tire sizes are 235/40/18 and 255/40/18
18" or 19" 5x114..3 wheels 8.5x30 front 9.5x38 rears. 235 Fronts and 265 Rears. I have 19x10 +38 rears with 265/30/19 Continentals and should of went with 275's or a 9.5" Wheel. My rear tires are stretched some and makes the tire hydroplane on wet roads.
Is it possible to get a nice flush fit with square set up? I really would like to be able to rotate my tires to extend the life of the tires. Thanks in advance 🙏
What’s flush on the front won’t be flush on the back. You’re going to have to use spacers to push the rear wheels closer to the fenders.
