Kick sensor trunk opening
Old Oct 14, 2021 | 06:27 AM
valeoray's Avatar
valeoray
Could you please tell me where you connected the green wire of the trunk opener?
I see there are 4 wires: red and black for constant power, white for ACC, and green (I suppose it connects to the trunk release switch at the bottom of the front dash?)
The translated instructions don't quite make sense.
Thanks!
Old Oct 14, 2021 | 02:46 PM
ahmed24's Avatar
ahmed24
Thanks!
Haha those translated instructions are a joke lol. You have constant power, ground and ACC then the green wire is the unlock signal. This goes to the trunk opener switch itself but on the ground switched wire. I can't remember from the top of my head as I did this early in the year. The easiest way to determine which of the two wires on the trunk switch it goes to just try and ground one of the pins while the fob is next to you and trunk is open. When you ground the correct one that you need to tap into you will hear the lock unlock. If that makes sense
xjokerz
Oct 7, 2021 06:38 PM
Dkawane
Jan 8, 2010 07:31 AM
heyitzalex
Oct 16, 2009 01:58 PM
Mr Jokster
Dec 7, 2008 03:54 AM
