Loose driver's side mirror - what could be wrong
Old Oct 6, 2021 | 10:52 AM
cfauvel's Avatar
cfauvel
Default Loose driver's side mirror - what could be wrong
Daughter came out to this:
Thoughts?
Old Oct 6, 2021 | 11:03 AM
MikeFig82's Avatar
MikeFig82
Old Oct 6, 2021 | 12:14 PM
cfauvel's Avatar
cfauvel
Brilliant !! Thanks
Old Oct 6, 2021 | 09:54 PM
Traxxer's Avatar
Traxxer
I've had that issue on both mirrors and used the exact video that MikeFig82 posted with success. I struggled using just weight alone to press down with the pipe wrench. What worked for me was to just line up the pipe wrench on the clip and hitting it hard with the rubber mallet. After the clip was secure, I used a worm gear hose clamp to prevent the clip from popping out again.
Old Oct 7, 2021 | 03:08 AM
Evil1nside's Avatar
Evil1nside
I have completely the opposite problem, lol.
My passenger side mirror, seems to be stuck, can't be moved in either direction.
I guess this still has something to do with this mechanism?
Old Oct 7, 2021 | 05:43 AM
cfauvel's Avatar
cfauvel
Once I get the clip down far enough, I'm thinking of drilling a hole into the cylinder and putting a roll-pin. Sometimes engineers don't engineer things correctly :-)
Old Oct 7, 2021 | 07:59 AM
MikeFig82's Avatar
MikeFig82
After so many times I fixed it. The washer didn't have anymore material to bite into. I eventually just tapped 2 6-32 screws in to the cylinder. Also I just went through my camera roll, and I must of deleted the pictures to show.
Roll pins would be good too.
This can all be prevented if you don't do automatic car washes. That's how mine got trashed in the first place. It doesn't take much force to knock it out of place.
Old Oct 9, 2021 | 09:48 AM
cfauvel's Avatar
cfauvel
Mother Fornicating Defecation Ballz!!!!
Fixed the nut thing, using an O2 socket and drilled 2 tiny holes and ran galv wire through the holes and busted the mirror as I was trying to snap the mirror back in place !!!!!
The very LAST step
Old Oct 10, 2021 | 10:43 AM
nosurprise's Avatar
nosurprise
lol; did you use Vaseline?
Old Oct 10, 2021 | 12:19 PM
cfauvel's Avatar
cfauvel
I thought I did better....silicone lubricant
appbury
NX - 1st Gen (2015-2021)
Sep 27, 2019 11:33 AM
rennwerkes
Apr 29, 2011 05:46 AM
booyabruin
Nov 3, 2007 12:02 AM
