ENGINE CODES!! VSC!! 2006 Lexus IS250
Old May 16, 2021 | 05:02 PM
MrXclusive's Avatar
MrXclusive
Default ENGINE CODES!! VSC!! 2006 Lexus IS250
Ok, so im new here. Just looking for tips and help. I have a 2006 Lexus IS250, automatic, 164k. The "Check VSC" light is on, along with the engine light. The codes I get on my reader are :
P0172 p0175 p0101
C1201 c1223 c1241
Any insight to what might be going on with my car would be super appreciated!! Thanks in advance. 😎✌
Old May 17, 2021 | 07:05 AM
2013FSport's Avatar
2013FSport
P0172 p0175 p0101
C1201 c1223 c1241
Hi and welcome aboard. Perhaps this is just me but I would appreciate OP looking this stuff up so I don't have too. Perhaps I dislike doing more work than necessary, IDK...
However, doing this action may just help you see when codes are related to work done and maintenance that should be done. Some are brand specific so go with Toyota Lexus OBD codes.
I say this as I'm out of time to do it for you...
Old May 17, 2021 | 08:56 AM
mandyfig's Avatar
mandyfig
You can google the codes...list them and start debugging.
Old May 17, 2021 | 10:13 AM
MikeFig82's Avatar
MikeFig82
First set of codes. You're running rich both banks. MAF related. Start by cleaning MAF sensor. Followed by an ECU reset.
Second set of codes. Most codes are related to maybe a brake light switch.
All this can be found on Google. Search Lexus ISx50 ... followed by symptoms, or codes read.
Old May 17, 2021 | 02:19 PM
MrXclusive's Avatar
MrXclusive
Thank you, just cleaned the MAF sensor and reset codes. Ill be sure to update in a few days. 😎
Old May 17, 2021 | 04:19 PM
MikeFig82's Avatar
MikeFig82
Did you reset by scan tool, or battery, fuse's?
I'd do the fuses method. You need to reset long term fuel trims.
See here: https://www.clublexus.com/how-tos/a/...our-ecu-363500
JohnnoHop1
Performance
Aug 13, 2020 07:48 AM
Mamba2481
Jan 14, 2019 12:13 PM
mbetsya
Mar 8, 2018 10:19 AM
Shumba
Build Threads
Oct 18, 2016 05:15 AM
Izaguirre
Jan 21, 2016 07:09 AM
