A/C venting help
Old Apr 29, 2021 | 12:38 PM
molson7's Avatar
molson7
Default A/C venting help
Hi all-
Just helped my son purchase a 2010 IS250 yesterday with an issue (knew about it prior to purchase). When running the air condtioning the 2 drivers side vents blow cold air but the passenger side blows regular air. Anyone else run into this issue?
Looking for advice on where to start diagnosing this. Seems strange that all 4 vents wouldn't be connected behind dash but thinking there may be flapper or something that's stuck in the closed position.
any help or suggestions are appreciated!
Old Apr 30, 2021 | 06:28 AM
Gville350's Avatar
Gville350
Any odd noises coming from behind the glove box area? Did the previous owner have a cabin air filter replaced and then immediately afterward start to have this issue?
Old Apr 30, 2021 | 08:42 AM
molson7's Avatar
molson7
No odd noises to speak of, in fact for a car with 140k+ miles it's amazing quiet both inside and out. Not aware of previous owner reports as i bought it from a dealer. Checked out history report on Lexus website as well and didn't see any mention of this issue.
I'm thinking there must be a damper stuck or something but was thinking maybe it's a problem someone else has run into and found a solution.
Old Apr 30, 2021 | 07:08 PM
nosurprise's Avatar
nosurprise
I had a similar issue a while back where my passenger side was blowing warm air and the driver side was blowing cold air. The issue corrected itself after I randomly adjust the temperatures on both sides and restarted the car a couple of times. I think there wasn't anything wrong with the system other than the control module somehow got confused. You can also try disconnecting the battery for 15 minutes to see if the settings get reset.
jjr2527
Feb 17, 2014 08:22 PM
sung35
Jul 4, 2011 12:08 PM
morris
Maintenance
Dec 16, 2005 07:00 PM
