Intermittent Transmission Problem!
Old Nov 15, 2020 | 11:38 AM
Ken167's Avatar
Ken167
Default Intermittent Transmission Problem!
Recently the trans has been occasionally slow and lazy to upshift to the next higher gear-- the engine RPMs just roll over without a sharp shift.
And last night while driving I hit the throttle and trans downshifted from 4 to 3 but the engine RPM surged up before shifting down to 3. But it only did that 1X time last night then the trans was shifting normal with no surging so I dont get it!!
5 mos ago the leaking trans gasket was changed out at Tustin Toyota and I wonder if they didnt refill the trans with oil correctly. Im going back there this week have them look at it!
Any ideas??!!
Old Nov 15, 2020 | 11:42 AM
AMIRZA786's Avatar
AMIRZA786
Any ideas??!!
If the issue started after fixing the leaking trans gasket (or shortly after), there could be the possibility of not enough transmission fluid or improperly adding fluid in a way that allowed debis to come loose. By the way the transmission seems to be acting its more likely incorrect fluid levels
Old Nov 15, 2020 | 11:57 AM
Ken167's Avatar
Ken167
Yea Im hoping its just improper fluid level and not the trans going bad!
Old Nov 15, 2020 | 12:00 PM
AMIRZA786's Avatar
AMIRZA786
I think your cool, just get it back to them ASAP before you do experience a transmission failure
Teamslo
RC F (2015-present)
22
Jul 16, 2021 12:43 PM
GFerg
Dec 18, 2020 12:39 PM
ionian
ES - 7th Gen (2019-2025)
Oct 23, 2020 04:42 PM
BTC89LS400
Sep 27, 2019 03:45 PM
