Waterpump replacement
Old Sep 27, 2020 | 03:47 PM
Sk8Surfr's Avatar
Sk8Surfr
Default Waterpump replacement
Noisy waterpump - and leaking - 165k miles. When I removed the water pump pulley - to get enough tension on the belt for the bolts to break loose the crankshaft turned. I'm assuming that's not an issue since the crank and cams are connected with a chain?
I'm used to the old Audis I owned that I had to lock the cams since they were all belt driven.
Old Sep 27, 2020 | 07:11 PM
AMIRZA786's Avatar
AMIRZA786
Yes, it's a timing chain so you don't have to lock the cams
Old Sep 28, 2020 | 04:27 AM
Sk8Surfr's Avatar
Sk8Surfr
Thanks - should I spend another $40 and replace the thermostat as well while I'm in there? I believe its original....
Old Sep 28, 2020 | 01:01 PM
B00M3R's Avatar
B00M3R
Absolutely. Cheap insurance for the future in my opinion.
714is300
May 21, 2020 08:08 PM
FamForce6
Feb 3, 2020 06:15 PM
danev2
Nov 25, 2019 03:51 PM
colenzae
RX - 1st Gen (1999-2003)
Apr 24, 2012 04:22 PM
Felix gs43
Performance
Oct 8, 2006 10:31 PM
