brakes
Old Sep 27, 2020 | 04:48 PM
mallybandz's Avatar
mallybandz
Default brakes
i have a 2007 lexus is250. whenever im trying to stop the vehicle, i have to push the brakes really far almost flooring it to slow down. is there a way to make the brakes more sensitive so i dont have to push so far. ive checked all the brake pads and theyre almost new
Old Sep 27, 2020 | 05:17 PM
DaveGS4's Avatar
DaveGS4
Administrator Emeritus
No expert, but sounds to me that it's more an issue with your brake fluid needing to be bled vs pads
Old Sep 28, 2020 | 04:27 AM
Speddon's Avatar
Speddon
I would check the brake fluid level. If it's low adding some fluid can help, but if there is a problem with the master cylinder, then there's nothing you can do except replace it. Have you had the brake pads changed recently or has anyone done a brake fluid flush recently?
Old Sep 28, 2020 | 01:53 PM
mallybandz's Avatar
mallybandz
they brakes are pretty new. i may need to flush the fluid
