Need Feedback On 4 Wheel Alignment
Old Sep 18, 2020 | 10:24 AM
Ken167's Avatar
Ken167
Default Need Feedback On 4 Wheel Alignment
I had a 4 wheel alignment done few days ago see below spec sheet. Top is before, bottom after. Camber negative and nonadjustable thats ok, thrust angle now zero, toe F and R was off so they adjusted that, but Im not sure about the specs esp the rear toe .12* ???
Old Sep 18, 2020 | 04:05 PM
2013FSport's Avatar
2013FSport
The thrust angle on the rear is better now. When you hit bumps it should drive straight through them vs darting. Both ends have a slight amount of toe-in, so check the wear and adjust the pressure until you get even wear on both ends.
I'm on 225 255 stager and run 39 PSI up front and 33 in the rear. This so far is getting good wear at both ends. Too low in the front and the edges get destroyed. To high in the rear and the center blew out, hence the psi I run today. Moral of the story, measure wear and adjust pressure. If still eating the inside edge, toe it in some more.
Old Jul 29, 2022 | 09:13 AM
Raven01750's Avatar
Raven01750
This is all I can tell you.
Paul
Old Jul 29, 2022 | 09:41 AM
footballpl's Avatar
footballpl
Seems like a lot of toe to leave, double what they set my rear toe at when I got my last alignment.
Old Jul 31, 2022 | 09:31 AM
2013FSport's Avatar
2013FSport
On a 26" tire diameter ( 255/40R18 ), that's roughly 0.050" per side. If the tires don't feather the outer edges, it will help turn-in entry to corners, 1/2 of that would likely be better for MPG's. It really depends if it's a highway car or city car usage wise.
theoryguy3
May 17, 2017 11:27 PM
jadeboy
IS F (2008-2014)
Apr 29, 2015 01:00 PM
jlawr
May 26, 2010 03:00 PM
Lexs400
Dec 13, 2004 03:18 PM
bishop977
Maintenance
Jun 15, 2004 10:16 AM
