Headlights Auto-on Sensitivity
Old Aug 9, 2020 | 11:10 AM
Kajnbabe's Avatar
Kajnbabe
Default Headlights Auto-on Sensitivity
Not sure if this is posted in another place but I could not find it. What does the Headlights Auto-on Sensitivity mean and what should it be set on? I googled it, searched here and I can't find it in my book or manual. Its one of the settings on the big NAV screen under "settings - lights - exterior". TIA
Old Aug 9, 2020 | 02:54 PM
dibl's Avatar
dibl
It is pretty obscure, for sure. It took me 10 minutes of searching in the manuals to find something about it, for my 2018. Under User Manual section 4-3, "Operating the Lights and Sensors", at the end of the section, p.255, I see "Customization" and it says "Some functions can be customized (--->P.722)". On page 722, I find "Automatic Light Control", and the first item in the little table is "Light sensor sensitivity", with a default setting of "Standard", and an available range of "-2 to 2". I THINK that is what your NAV screen settings are referring to. I would guess that going to -2 will reduce sensitivity -- i.e. the headlights take longer in the morning to turn off, and take longer in the evening to turn on. Going to a setting of 2 would reverse that timing.
Old Aug 10, 2020 | 04:55 AM
Kajnbabe's Avatar
Kajnbabe
Thanks so much for your help! I really appreciate it. I presume with my settings from 0-5, the closer to 5 the sensitivity will be greater, meaning the earlier the lights will come on in the evening & will take longer in the morning to go off. I will call the dealer tech dept this morning and check. I sure don't need them to come on later in the evening.
Old Aug 10, 2020 | 05:01 AM
dibl's Avatar
dibl
My presumption is the same as yours -- but I've never changed from default. Go with what your dealer tech advisor says.
Old Aug 10, 2020 | 06:39 AM
blayze1983's Avatar
blayze1983
I find the default setting to be pretty responsive so I'll just keep it at that - my test is tunnels - if it turns on fast enough when I hit a tunnel then that's good enough for me.
But good to know how to tweak it - let us know once you confirm which direction makes it more/less sensitive. Thanks
Old Aug 11, 2020 | 06:35 PM
Kajnbabe's Avatar
Kajnbabe
Hi, Spoke with tech department at the dealership, you and I both are under the same and dealer confirmed the higher the number the more sensitive and the lights will come on before dark. Thanks again for your help.
Old Aug 12, 2020 | 02:39 AM
dibl's Avatar
dibl
Great -- learned something today!
Old Aug 12, 2020 | 07:45 AM
mcomer's Avatar
mcomer
Light Sensitivity changes the threshold of ambient light that triggers the change
but not the time delay that occurs once the level is crossed. Notice when you
back out of a garage into daylight, lights are on and Nav screen is dark? You
will see the Nav screen brighten up almost immediately upon entering daylight
but the "green lantern" dash icon that indicates the headlights stays on for another
15 seconds.
Old Aug 12, 2020 | 08:31 AM
blayze1983's Avatar
blayze1983
15 seconds.
This explains a lot thank you. For some shorter tunnels, the lights don't automatically turn on during the day (so I have to manually do it sometimes), but other longer tunnels it eventually comes on. So increasing sensitivity will do nothing to help in this scenario. I always mistakenly thought the sensitivity changes response delay.
Old Aug 12, 2020 | 11:16 AM
mcomer's Avatar
mcomer
The adjustment seems to apply when 1) you live where it is cloudy much
of the time, 2) you commute at dusk and/or twilight, 3) you have somewhat
reduced vision particularly at night. Tweeking the setting to enable the lights
sooner might aid any of those.
There are now also settings for how bright you might like the BSM icon to glow
in the rear view mirror as well as the range that BSM "sees" adjacent cars.
Old Aug 17, 2020 | 04:37 AM
Kajnbabe's Avatar
Kajnbabe
Two things...
1. I have my headlight sensitivity setting to #2 and took the car out the other evening around 7::15pm and once out the garage about 2 minutes, headlights came on. That was my goal for my lights to come on around 20-30 minutes prior to nightfall.
2. How do you set "There are now also settings for how bright you might like the BSM icon to glow in the rear view mirror as well as the range that BSM "sees" adjacent cars."?
rclab1
Jan 26, 2024 05:43 AM
Jazzrock
Dec 6, 2019 10:37 AM
jer
RX - 3rd Gen (2010-2015)
Feb 9, 2015 08:29 AM
Copguy
Nov 16, 2010 02:01 PM
NeilB25
May 10, 2010 02:33 PM
