Check VSC: just C1201 code
Old Jun 19, 2020 | 12:39 PM
rousseau's Avatar
rousseau
Default Check VSC: just C1201 code
Since getting all four TPMS sensors replaced my (non-Lexus) mechanic hasn't been able to clear the dashboard on my 2006 IS350. I've got the VSC, traction control, check engine and AFS lights on. The only code that comes up is the C1201, but apparently that could mean anything.
Any suggestions?
Old Jun 19, 2020 | 12:44 PM
2013FSport's Avatar
2013FSport
Any suggestions?
Anything? https://www.clublexus.com/forums/es-...057-p0161.html
Check the brake system and fluid level.
Old Jun 19, 2020 | 01:34 PM
rousseau's Avatar
rousseau
Thanks, I'm going to get the brake fluid flushed and re-upped and the brake pads checked next week. It's a fourteen-year-old car that I've had for six years, so I don't know the last time the fluid was ever checked (uh, probably when I had the brakes done last?).
Old Jun 23, 2020 | 03:40 PM
rousseau's Avatar
rousseau
Just got this done today and had the codes cleared. So far the dashboard is clear. Fingers crossed!
Old Jun 25, 2020 | 06:52 PM
rousseau's Avatar
rousseau
The warning lights came back on while driving today: VSC, traction control, check engine and AFS lights. Back to the drawing board.
What can I try now?
Old Jul 8, 2020 | 07:09 PM
rousseau's Avatar
rousseau
Thought I'd bump this just in case anyone had any suggestions.
Old Jul 9, 2020 | 09:10 AM
2013FSport's Avatar
2013FSport
Inside the reservoir is a float. Make sure it is floating. If you have a DMM, you can disconnect the wire from the reservoir ohm it out and then suck the fluid out and measure again. See if it changes.
Maybe the float sank?
Usually when low it would read infinite ohms. And full it would read like 1 to 3 ohms. That said, watch what the light does when you unplug it and plug it back in. Maybe see if you can see the float and shake it free or pull it up.
Old Jul 9, 2020 | 05:30 PM
rousseau's Avatar
rousseau
Thanks for that. Though I'm fairly certain the mechanic saw the gauge thing in the reservoir when he replaced the fluid.
It's frustrating having only the C1201 code. Seems vague.
Old Jul 25, 2024 | 07:07 AM
coof11's Avatar
coof11
3rd Gear
Hi, I know its been a while and I assume you found a solution? I'm having the same trouble. Thanks
Old Jul 25, 2024 | 08:41 AM
rousseau's Avatar
rousseau
My mechanic flushed the brake fluid. That seemed to take care of it at the time. Hope this helps.
h4jonathan
Jan 26, 2020 07:55 AM
Orion7
24
Jun 21, 2018 02:32 PM
Huggies
Jan 17, 2018 12:54 PM
Joppa013
Oct 27, 2017 12:44 PM
RC1047
Feb 3, 2011 12:53 PM
