IS350 E85 custom tune result!
Old Dec 2, 2020 | 11:21 AM
  #31
Pittsy's Avatar
Pittsy
Originally Posted by Thannp
Some updates
It has been about a year since I did the tune. Put on about 19,000 Mile on the engine with E85 only.
Lots of midnight run and pulls. No track day yet because of covid-19. Averaging about 15 MPG for the last 19,000 mile
Still on stock injector and fuel pump.
No leaks and corrosion on the fuel line
please tell me how i can get a hold of this tune!
is it flex fuel based off of o2’s and maf? Or strictly e85
Old Dec 2, 2020 | 08:41 PM
  #32
Thannp's Avatar
Thannp
I did custom ECU remap with a reputable ECU tuner here in thailand and it is not flex fuel. E85 ONLY
Old Dec 3, 2020 | 06:04 AM
  #33
Realzking1's Avatar
Realzking1
Do you have some type of social media ?
Old Dec 3, 2020 | 10:00 AM
  #34
Thannp's Avatar
Thannp
I do but I dont post car stuff there often here is a link for my 0-150 mph run on utube
Old Dec 3, 2020 | 10:18 AM
  #35
Realzking1's Avatar
Realzking1
https://youtu.be/xH5RdSOTLxY
Ive watched this before ! If you got snap add me back it’s Realzking1
Old Dec 1, 2021 | 08:24 AM
  #36
jgscott's Avatar
jgscott
Hi Thannp,
I know this is old. But would your Tuner sell that Tune map to anyone and/or load if someone sent them a ECU?
Also are you saying the only cam timing done was with the Tune, not a cam adjustable degree sprocket wheel or something right? Just the Map to change cam timing on the stock tune???
Old Dec 5, 2021 | 09:05 AM
  #37
Thannp's Avatar
Thannp
Originally Posted by jgscott
Hi Thannp,
I am based in Thailand as well as the tuner. would that be a problem for you ? cause shipping the ECU back and forth won't be cheap and it will take a few days.
If that is ok for you I will ask him if he would load the tune for you and how much he would charge.
and to answer your question. I don't think he did anything with the cam timing. but he did advance the Ignition timing map to take advantage of the higher octane from E85
Old Dec 5, 2021 | 10:48 AM
  #38
jgscott's Avatar
jgscott
Yes I could send. I have a spare ECU to use to send that matches up with my car. Yes let me know what he thinks cost wise for just a loaded map? Thanks.
Old Dec 10, 2021 | 03:22 AM
  #39
Thannp's Avatar
Thannp
Hi I am back with the answer
Tuner said yes he will do it for 500$ but you need to provide him with some info relating to your car current modification Eg. Does it have any cat? what is your current exhaust setup/ is your car FBO and also what is your E-% on your local E85 GAS.
He does not believe that my map will run good on your car due to the differences I mentioned above.
so he need the info to make the map to suit your setup..
He also suggested that you may need a local tuner on your end to make some fine adjustment if you are looking for the best possible output
let me know if you are still interested
Thannp
Dec 3, 2020 09:55 AM
gerrb
Oct 12, 2012 09:45 AM
DJ420a
May 4, 2010 12:32 PM
j_version_
May 22, 2008 03:53 PM
JTJerryls400
Mar 21, 2005 09:28 PM
