HELP pls. American IS350 in Europe
10th Gear
Have issue with my is350/2007 here in europe with navi screen is in error and this error or destination disfunction causing not working navigation, menu button and for example in rear camera I don't see guide lines. I was trying to insert there maps from my corolla verso 2006, but without any change. Guys from lexus told me that there should work re-flash of navi rom, but they don't have equipment...any idea how to fix it?
10th Gear
Hmmm..... what about "...I was trying to insert 3 maps from 2006 Corolla?" That could have been a factor.
Are you saying someone before you tried this or you tried this?
What model is the radio/Nav unit? It is listed at the very bottom of the head unit.
Also you may be able to A) gather more info or B) reset it.
A)
Anyone wanting more info about their audio, Nav, Amp, or anything else in the center;
With engine on, vehicle stopped, turn the light switch to OFF. Press and hold the Info button and turn the light switch on then off 3 times. The touch screen will go into a new mode offering options for equipment versions, hardware versions and diagnostic features. You will also find settings for mic input and bluetooth volumes. Could be helpful if someone can't hear you.
Here are some crappy pictures. Units with Nav will have more options.
Turn the key off when done.
B) Press and hold the on/off button, continue holding down until it reboots. Mind you I take no responsibility for it getting any worse if that is possible.
Info came from here...https://www.clublexus.com/forums/bui...nance-diy.html
10th Gear
Thank you for help, I was trying, to try if system will load data from dvd (2006 europe)
Type of my navi system is P6500
Was trying to restart system by holding button on/off, but no reaction.
10th Gear
Looks like I need original navi dvd from 2007 based on this
https://www.clublexus.com/forums/is-...-a-dealer.html
Any idea how to download old ones here in europe?
Think that original dvd is lost and my 2006 from toyota is different firmware...
Canonsveg
06-20-19 05:20 PM
Emoney0826
07-17-14 12:04 PM
