Hello, i have bought this android interface from Aliexpress but i need some help with installation. The sent me this power cable with the grey connector but it doesnt fit anywhere in the original radio. Does anyone have an idea where to connect this? Pictures below:
2nd row from bottom, 2nd socket. Should be a 12 pin socket. Most add on items are connected there.
It doesnt fit there. I contacted supplier the told me to get power from some wire sinds its not plug and play. I did and its working fine but you have to disassemble the radio in order to use the touchscreen by putting in sort of an fpc adapter. So i got it working but i messed up putting the radio back i burned a fuse. The one that powers the stock ipod but i cant seem to find that fuse. Anyone know wich one it is?
Here are some poctures. Its working fine now. The only problem is the backup camera which i didnt connect to the box. Also if you are in android mode the touch in the stock doesnt work. You have to switch back to normal mode in order to use touch for example to change temperature. Other than that it works flawless.
