Headlights fluttering
Old Jan 28, 2019 | 08:29 AM
jdc916's Avatar
jdc916
Default Headlights fluttering
I have a 2011 IS 250 F Sport........ recently the headlights appear to be fluttering.
If I stand in front of the are and look at the bulbs, you cant see anything happening. But if you turn and look at the light that is cast, you can see the "dancing" effect.
Anyone else have this problem or know what the fix is ?
Thanks
Old Jan 28, 2019 | 08:48 AM
maeveLexi's Avatar
maeveLexi
I have a 2008 IS 350 and it started happening when I changed my headlights.
I also have no idea what's causing it.
Old Jan 28, 2019 | 08:53 AM
Zmon's Avatar
Zmon
Are they HIDS or halogens? If they're HIDs, is it occurring on both sides or just one? If just one, swap the bulbs side to side and see if the issue follows the bulb (if it does, bulb is bad, if it doesn't, ballast is bad).
Old Jan 28, 2019 | 09:11 AM
jdc916's Avatar
jdc916
ZMON, I believe they are the HIDs and its both of them.
Old Jan 28, 2019 | 09:16 AM
jdc916's Avatar
jdc916
Also, it doesnt appear that they are shining far enough ahead anymore either.
Old Jan 28, 2019 | 12:32 PM
2013FSport's Avatar
2013FSport
The D4S bulbs do not live as long as the older D2S.
If the light output is indeed on the decline it is very likely the bulb.
My 2013 bulbs died just past the 5 year 50,### mile mark. They would light, flutter, turn orange and then turn off.
Do NOT touch the bulb or it die when it heats up.
Old Jan 30, 2019 | 08:25 AM
jdc916's Avatar
jdc916
thanks 2013FSport
Old Jan 30, 2019 | 08:44 AM
jdc916's Avatar
jdc916
Wow ! A D4S bulb is anywhere from $105.00 to $150.00 !!!
Thats crazy !
Can you use D2S' instead since they are only about $65 ? And has anyone done this ?
Thanks
Old Jan 30, 2019 | 09:48 AM
Zmon's Avatar
Zmon
Thats crazy !
Thanks
No, you'll have to use D4S bulbs. If you don't want to pay the premium for OEM bulbs, you can buy an aftermarket set of D4S bulbs from TheRetrofitSource for $60.
Old Jan 30, 2019 | 10:38 AM
jdc916's Avatar
jdc916
Thanks Zmon......
After doing a bunch of reading on this, yes, I have found that you can not use D2S in place of D4S
Old Jan 31, 2019 | 06:20 AM
2013FSport's Avatar
2013FSport
I've got about 16 months on the Morimoto XB 55000k. So far so good. $60 for the pair.
I am not recommending this but you can modify the tabs to fit either housing. I threw an old D4S bulb in D2S Acura LX housing just to test its light output. Mind you the 35w ballast designed for later bulb types fired it off no problem. Also note that aftermarket replacement ballasts typically say they work for either bulb.
Old Jan 31, 2019 | 06:39 AM
Zmon's Avatar
Zmon
A D2S bulb will simply not work with a D4S ballast after the initial ignition. The voltage will drop under the required 85v for the D2S bulb and it'll shut off. D4S only needs 42v as a reference. Although, there are a couple ballasts on the market that can power both (e.g. Hella Gen 3), but our ballasts can't do both (iirc, they're only rated for the 42v)
I did mention the XB's above to the OP, the D4S set is only $60 so he just assumes go that route. Would highly recommend not modifying your bulbs or projectors to take D2S bulbs.
Brandon593
Sep 15, 2021 09:36 AM
Stun350
Jan 12, 2014 07:59 PM
sopa
Aug 26, 2013 06:02 PM
