fuel running of # 5 cylinder, replaced all injectors, have spark at each spark plug, gas running down block below #5 cylinder exhaust. What am I missing? ECM I hope not $1,800.00
If fuel is leaking OUTSIDE of the engine, and then assuming the injectors are sealed correctly, then start checking all of the fuel delivery lines and connections between rails and hoses and such.
Good luck!
Good luck!
