Rod knock???
i have 2008 is250 160k. Mine has the famous rattle at startup which is the intake cam gears. Yours could be that just worst symptoms, from my understanding the cam gear wears out and gets loose or something, correct me guys if i am wrong. I am in your shoes too not sure if its worth fixing. I would fix it my self no problem there but not sure.
There's definitely something happening that shouldn't be. So this all started when you started it up stone cold and you got what was probably referred to as the "cam rattle". Then this knocking started thereafter? Is this RPM-dependent?
Yea after I started the car I heard i guess the cam rattle and now I hear this knock consistently. I haven’t drove the car because I’m worried it could get worse. So I’m not sure if it is rpm dependent.
CrazyLex
Jul 22, 2011 12:02 PM
