Gas Smell When Engine Cold
Old Dec 4, 2017 | 09:53 AM
mcastro's Avatar
mcastro
Default Gas Smell When Engine Cold
Hi all- wondering if anyone has gotten this issue? I get a gasoline smell when the engine is cold or in the morning when the weather is cold. Once the engine is warmed up, the smell goes away. The smell seems to come from the middle of the engine underneath the intake. The car is an 07 IS350 with the fuel pressure regulator gasket recall done.
Old Dec 4, 2017 | 12:32 PM
Gville350's Avatar
Gville350
Perhaps purchase a fuel-safe UV dye that will help you locate the source of the leak under the hood. Yes, you will need a black light.
Old Dec 5, 2017 | 12:04 PM
mcastro's Avatar
mcastro
Originally Posted by gville350
perhaps purchase a fuel-safe uv dye that will help you locate the source of the leak under the hood. Yes, you will need a black light.
thanks will try that!
WolfyLS460
Hybrid Technology
Feb 2, 2017 12:31 PM
Eolafan
34
Feb 13, 2016 06:52 PM
toytrain13
15
Dec 11, 2015 06:05 AM
Fixman
Aug 3, 2015 12:45 PM
RD400H
Hybrid Technology
May 21, 2008 12:20 PM
