Wheel disk clearance
Old Jul 16, 2017 | 01:14 PM
laobo979's Avatar
laobo979
Default Wheel disk clearance
Anybody know or running mid disk rim? Want to know if they clear is350 caliper or do I need spacer.
Old Jul 17, 2017 | 06:06 AM
primavera's Avatar
primavera
What's mid disk rim?
Old Jul 17, 2017 | 10:45 AM
laobo979's Avatar
laobo979
i a term for wheel caliper clearance. Most Japanese wheel brand have high,mid. Or low disk for discribing caliper clearance for fitment. I know high clear bbk and low won't. Wondering if any body run a Mid disk to clear the 350 front caliper.
Old Jul 17, 2017 | 11:42 AM
flowrider's Avatar
flowrider
Veteran: Air Force
Never heard of those terms. When speaking of wheels, I and many others on this forum and other automotive forums speak in terms of wheel offset. One thing I can tell you about IS350 calipers is that they are thick, and ISF wheels (8"- 45mm offset) will not fit on the front of an IS350 without small spacers
Lou
Old Jul 17, 2017 | 12:35 PM
laobo979's Avatar
laobo979
It's a term with those who have bbk caliper were it truly matter. Different company's have different saying and different fitment even with same spec. Cause the face plate play a lot in the clearance of caliber with what disk it is. Two rim same spec same brand. One is high disk will clear bbk and one low disk won't clear even tho same spec.
Old Jul 17, 2017 | 03:49 PM
Gville350's Avatar
Gville350
If you're a wheel fanatic, you'll know that term. Though I know what that term means, I don't know what would or would not work on the IS350. I've only ever had factory and factory Genesis Track wheels on mine; so nothing with a 4-digit price tag or JDM.
I'm sure someone with more insight will reply soon.
Old Jul 17, 2017 | 06:42 PM
laobo979's Avatar
laobo979
Yes offset one thing Disk is another. Looks like I'll need 5 or 10mm to fit them. Hoping it's 5mm to clear so I can rebarrel them inch wider.
l33ks
Suspension and Brakes
Jan 20, 2018 01:35 PM
iinkz
May 16, 2016 07:30 PM
boosted516
Aug 6, 2012 09:09 AM
XhyDra
Oct 7, 2011 04:08 PM
CarbonDtls
Apr 26, 2011 10:25 PM
