Daytime running lights/High Beam issue
Old 05-31-17, 06:39 PM
oespinoz
oespinoz's Avatar
Question Daytime running lights/High Beam issue
Hi guys,
My driver side DRL burned out so I replaced both sides(driver and passenger). I don't know what's the issue but after replacing it, the driver side still not working. I checked all fuses, engine compartment fuse box and under the dashboard..
I cant figured out what could be the reason.
Any suggestions?
Thanks.
Old 06-01-17, 08:42 AM
jr4div2
jr4div2's Avatar
I'd only suggest that maybe the replacement is bad. Get a volt meter and make sure you have voltage to the DRL connector that is still out. If not, I don't have much more to add. If you do have voltage, the connector may not be making proper contact to the replacement.
Old 06-01-17, 08:52 PM
whitebeast
whitebeast's Avatar
Did you check the hidden fuse under the hood. I mean the small box content the fog light fuse
Rattfinkk
02-19-24 10:48 PM
Donmemon
ES - 6th Gen (2013-2018)
12-03-17 02:06 PM
SSmith
SC- 1st Gen (1992-2000)
08-16-16 07:52 PM
Orcala
RX - 1st Gen (1999-2003)
04-26-13 02:05 AM
Quick Reply: Daytime running lights/High Beam issue
