Cracked side mirror
Accidentally cracked driver side mirror when installing puddle lights, looks like I only need to replace the mirror.
Has anyone tried replacing the glass from Mirrorglassplus?
http://mirrorglassplus.com/2010-lexu...FUU2gQodJ6UIqA
haven't gone through that website I've replaced a mirrors with Burco brand and they are good. Are your mirrors auto dimming? The link you posted goes over your broken glass so it doesn't sit inside the black trim around the glass (looks slightly different because it's out further). If your mirrors are not dimming, go with the heated version. It is slightly more money but replaces the glass and sits flush for an OEM look.
np, found out the hard way myself.. when you install separate the black ring from the backing plate, snap the back piece in place then mount the mirror. You'll avoid cracking it and the outer ring will hold it securely in place for the adhesive to take effect.
Bumbobee
Feb 25, 2009 09:21 AM
