Brakes, ABS, and P/S Lights turned on while I was driving my IS250 2007
Old 10-05-16, 12:33 PM
jpouerie
jpouerie's Avatar
Default Brakes, ABS, and P/S Lights turned on while I was driving my IS250 2007
hello guys,
Last night I was driving home when suddenly the break, ABS and P/S went on at the same time, this morning I noticed that the A/C panel is not responding and Temp indicator is not working either.
I took the car to the service center and they noticed that battery was lower than the optimal level, could a damaged battery causes this issue ?
Old 10-06-16, 03:12 AM
Bichon
Super Moderator
Bichon's Avatar
My guess is a bad alternator. Did the service center check for that?
Old 10-06-16, 08:19 AM
jpouerie
jpouerie's Avatar
Thumbs up
Thanks for your suggestion but I already fixed the problem few hours ago.
I disconnect the negative terminal from the battery for 20 mins and after that, no warning lights on and the A/C unit was functional again, I was recommended to buy other battery.
This thread can be closed.
swat1727
01-15-19 02:53 AM
ard4484
10-23-18 09:49 PM
msh34646
08-07-17 07:37 PM
LexLuki
04-25-14 02:38 PM
jewelerz
Maintenance
11-01-03 01:15 PM
Quick Reply: Brakes, ABS, and P/S Lights turned on while I was driving my IS250 2007
