Vais IVIC-5DR (Android Integration System)
Old Jul 20, 2016 | 09:55 AM
akoster's Avatar
akoster
Default Vais IVIC-5DR (Android Integration System)
So I was scrolling around on Vais Tech's website and came across this product that would allow you to integrate your Android phone into the Lexus touch screen system for 2006-2009 models. It's $399.
Anyone ever used this before? If so, does it work and worth buying?
Link: http://www.vaistech.com/newsite/product/ivic-5dr/
Old Jul 25, 2016 | 01:43 PM
meiermatt's Avatar
meiermatt
5th Gear
I have one for sale.
Brand new and i'm throwing in a bonus DC to DC power convertor - 3A 5V USB output. all for $375
PM me for details.
Old Jul 26, 2016 | 11:25 AM
JeeKay's Avatar
JeeKay
I've only had my IS for about 3 months now but this was the first mod I did, my car came with an Ipod input but it really sucked and I really wanted to get video on there or at least bluetooth streaming which is when I came across this unit. I tried finding reviews but could not come across anything that really made me feel like this was the right unit to buy, but I really wanted android integration so I went for it. I have tried android screen mirroring in my other cars using Pioneer head units with App Radio mode and an app called ARUnchained.
My experience buying this wasn't all that great, the customer service wasn't very great, the instructions were pretty crappy and generic, for example towards the end there are two modes you can choose between with dip switches but they don't tell you anything about the modes, why they're different or how to choose which one to use.
That being said the installation was pretty straight forward. I read somewhere (might have been in the instructions or a write up) that the VAIS box can be hidden behind the head unit, I didn't see much room back there and ended up putting mine on the right side of the transmission tunnel (not ideal). I used a Samsung MHL adapter and tried initial set up with my Note 5 (which isn't exactly supported) but ended up using my old Galaxy S3 as the stay-in-car phone and just tether data from my Note. Setting up the unit was another story, it took quite a bit of time to get everything working right but now it does work right.
The unit takes a long time to boot up but does work as intended. I don't have any connection issues anymore but the app used drains my phone even when not in use (I use an app to turn my phone's screen off) which seems odd considering it's plugged in 100% of the time but I digress.
All in all I would most likely buy this unit again as it does do what I wanted which is the ability to use music apps and have the steering wheel controls switch songs, stream youtube & netflix (only when parked)
I rushed through this post but if you have any specific questions just ask
Old Aug 3, 2016 | 01:05 AM
1jz68u's Avatar
1jz68u
Fantastic write up and review.
Old Aug 5, 2016 | 08:28 AM
akoster's Avatar
akoster
Thanks for the awesome write up. I will definitely be looking into getting one. Just wish it wasn't so pricey.
Old Aug 5, 2016 | 09:32 AM
JeeKay's Avatar
JeeKay
It is quite spendy, but I seen a couple ads for quite a bit less used, just seems they don't come up often.
When I ordered mine I contacted VAIS and they told me they didn't have one in stock but directed me to someone on the east cost of Canada who also didn't have any. Then VAIS got back to me saying they found one in stock so I ordered that unit. It had a sticker of 2016 on it but during start up it shows 2014 so I don't think these units get updated much so finding a used one should work just fine.
I did figure out how (not why) this set up drains my phone battery, when my phone (which stays in the car 24/7) gets power from the MHL cable attached to the VAIS box the screen stays on constantly, even when the car is turned back off which drains the battery. I haven't figured out a way to stop that from happening other than disconnecting the cable whenever not in use, but I did go into the app settings and disable port monitoring which did not solve the issue.
It would be good to know if others leaving the phone connected 24/7 face the same issue or if it's just an issue with my setup.
Old Sep 7, 2016 | 10:36 AM
Motzi21's Avatar
Motzi21
Deleted, sorry, wrong tread
Old Sep 7, 2016 | 11:15 AM
JeeKay's Avatar
JeeKay
Since this thread popped back up to the top, I would like to update my experiences. I have started having issues with it cutting out to a blue screen, sometimes with loud static, generally happens when shifting from park to drive (through reverse) and vise versa, but also has happened on a few occasions randomly.
*I have been using the same phone the whole time as I use my old S3 as a dedicated device for this kind of thing but I will have to use my day-to-day phone to see if this problem still happens. The thing is my day-to-day phone is a Note 4.5 (Note 4 hardware with a Note 5-ported rom) which wasn't a supported option during set up, but the Galaxy S3 I use in my car was supported so if I have issues with the Note it's hard to fault VAIS
Old Sep 18, 2016 | 07:14 AM
sashax415's Avatar
sashax415
Any videos of this in action?
Old Sep 19, 2016 | 11:18 AM
JeeKay's Avatar
JeeKay
Not as of yet but I have thought about making one
Old Aug 16, 2017 | 12:32 PM
seannay's Avatar
seannay
Afternoon! I have the iVic5D available! It came with my '08 RX350, but I am simply not using it to it's full capabilities. Let me know if you are still looking for one seanwilliamrobertson@gmail.com
*Product has since been sold, thanks CL!
Old Dec 5, 2017 | 08:42 PM
Lawh8rz's Avatar
Lawh8rz
PM me for details.
did you ever get rid of your ivic
Old Dec 6, 2017 | 05:56 AM
Phantom_89's Avatar
Phantom_89
I purchased one in 2014 and it was running fine until recently. I did a firmware upgrade they sent me and it shortly after it stopped recognizing my phone. I've been emailing back and forth with support but we have not found a solution.
Anybody else run into any issues with this? I checked the MHL adapter and the HDMI cable they both work. Also newer phones aren't using MHL anymore so you have to find a work around to connect to HDMI with them. I saw one guy use a Microsoft display adapter sucessfully. Others have tried to use chromecast but have not had great results.
Old Dec 8, 2017 | 10:09 AM
jodycochra's Avatar
jodycochra
I am selling a similar unit if anyone is interested.
It is new in box, and comes with HDMI cables.
https://www.ebay.com/itm/263366200679
Old Feb 26, 2018 | 07:03 AM
Phantom_89's Avatar
Phantom_89
I checked my MHL adapter again and turns out it was the culprit. I'm using this now with the Microsoft display adapter and my S8+. It works but the screen does not fill up completely like it did before.
sethlamb
Aug 26, 2015 02:00 PM
ClearP
Mar 29, 2011 10:15 PM
XxGoKoUxX
Mar 1, 2010 02:41 PM
jlalclk
Jun 12, 2006 06:22 AM
db6
GX - 1st Gen (2003-2009)
May 15, 2006 08:18 AM
