navigation dvd question
Old Mar 23, 2016 | 07:58 AM
hirsch2is's Avatar
hirsch2is
Default navigation dvd question
hello all. so this might be a dumb question but i am trying to change my navigation dvd to an updated one but when i go to eject the old dvd it doesn't come out. does the dvd stay in the reader at all times or is it something you pop in, install and then remove and I'm just stupid trying to eject something that isn't in there?
Old Mar 23, 2016 | 08:59 AM
Bichon's Avatar
Bichon
The DVD does not go into the CD changer, there is a separate optical drive behind the panel with the clock. You need to remove the panel with the clock by inserting the pin tools into the holes and pulling it out, revealing the DVD loading slot.
Old Mar 23, 2016 | 05:47 PM
Gville350's Avatar
Gville350
https://www.clublexus.com/forums/att...isc-access.jpg
NAV unit is behind the panel in the pic above. The tools should be in the tool bag in the trunk of the car in the center binding of the tool container.
Old Mar 25, 2016 | 01:24 PM
hirsch2is's Avatar
hirsch2is
ah thank you. i was worried i was gonna have to replace the cd changer
Old Mar 25, 2016 | 05:12 PM
MRKIS250's Avatar
MRKIS250
I actually did this yesterday. 2 things that were very helpful to know is push the tools all the way in. The other is put slight pressure in on each and pull the panel out. DON'T use a screw driver to pull out. I found several how to videos saying you need to do that. As you can see in the link the tools push in the brackets holding it in place. I wish the previous owner of my car knew that I have small indents on each side of the panel where they pryed it out.
Old Apr 18, 2016 | 03:31 PM
mandyfig's Avatar
mandyfig
2006 IS, is it GEN 4 or GEN 5?
Old Apr 18, 2016 | 04:15 PM
Bichon's Avatar
Bichon
It is GEN5.
ISMY350
CL of Southern California
Nov 1, 2011 07:28 PM
HiNrOunDuP
Oct 31, 2007 10:56 AM
uhohitzmik
Hybrid Technology
Dec 26, 2006 06:56 AM
Indecisive
Nov 10, 2005 06:27 AM
beryfitz
Feb 24, 2005 06:55 PM
