Bearing issue
Old Feb 11, 2016 | 01:29 PM
Rezasaba's Avatar
Rezasaba
Default Bearing issue
Just bought a used 2010 IS 250 with 87000 miles on it dealer will fix it my question is has others had this issue? I am wondering also the tires pressure sensor is on its this a winter issue? Still learning the ins and outs of the car the hard to is a blast t watch it open and close only had the ar for 2 days my first used car hope it goes for another120 k with no issue car is very clean except he two issues mentioned also can not find the button for seat heat
Old Feb 11, 2016 | 02:44 PM
toyoman29's Avatar
toyoman29
I've had no bearing issues with my 2010, the TPMS light may be only the air pressure low or a small leak in one tire, let the dealer take care of it. The heat for the seat is on the same dial for cooling, just roll it the other direction.
Old Feb 11, 2016 | 10:10 PM
Rezasaba's Avatar
Rezasaba
THANX Toyoman29 found the dial for seat Heat thanx for the info
Old Feb 11, 2016 | 10:28 PM
isfdude's Avatar
isfdude
My wheel bearings went bad at 60k on my is350.
Old Feb 12, 2016 | 12:25 AM
Rezasaba's Avatar
Rezasaba
Wow 60 K thats premature ¿! Do.you remember which side ? I have 2009 Tacoma 4WD and fromt bearing went at 125K
Old Feb 12, 2016 | 01:30 AM
isfdude's Avatar
isfdude
It was my driver side hub bearing that went so I replaced both sides with OEM also known as SKF.
Old Feb 12, 2016 | 11:46 AM
Rezasaba's Avatar
Rezasaba
Thanx for the info
Old Feb 12, 2016 | 01:12 PM
toyoman29's Avatar
toyoman29
I have a 2005 Tacoma 4WD and replaced passenger side front wheel bearing at 115K, the Tacoma's bearings going out are pretty common.
Old Feb 12, 2016 | 01:29 PM
Rezasaba's Avatar
Rezasaba
Yes I know in 2009 after I bought the truck at about 8k Draler told me he has to replace the bearing under warranty told me it was Toyota recall I had no issues at the time with it So he changed one side and 100 +k later I changed the other one still a mystery to me
1halifax
NX - 1st Gen (2015-2021)
Apr 26, 2018 07:45 PM
tucker21
Jun 1, 2016 07:07 AM
3894days
RX - 3rd Gen (2010-2015)
Mar 26, 2015 06:57 PM
stanatl
Feb 20, 2010 06:59 PM
