Front LCA Bushing
Old Feb 10, 2016 | 11:56 AM
Tungstn-IS's Avatar
Tungstn-IS
Default Front LCA Bushing
I am looking to replace the worn LCA bushings on the front end of my '06 350 Sport Package. I was just going to go with the OEM zero offest part but I had some questions. I had read else where on here that they were the same regardless of side, but looking online I see two different part numbers for left and right (4807530030 / 4807630030). What's the deal with that?
Also, are they the same part for RWD and AWD models?
Old Feb 10, 2016 | 12:18 PM
Tro209's Avatar
Tro209
I don't know much about the OEM bushings to be honest but as a suggestion, why not just go with the USRS from RR-racing? They improve the feel and handling of our cars (according to what member have said anyway). This way you not only replace your worn bushings but also upgrade at the same time.
Old Feb 10, 2016 | 12:53 PM
Tungstn-IS's Avatar
Tungstn-IS
I've read where a lot of people upgrade to those or the Figs, but they're over 5 times what I can get the OEM bushing for. I'm just not that concerned about it for a vehicle I drive up and down the freeway in.
Old Feb 10, 2016 | 12:59 PM
Gville350's Avatar
Gville350
^Have you experienced any irregular front inner tire wear? The aftermarket poly LCA bushings fix that.
Old Feb 10, 2016 | 01:03 PM
Tungstn-IS's Avatar
Tungstn-IS
I just started to see some inner tire wear, that's how I found the worn bushing. Actually can't visually see the tire wear, but I can hear it beginning at low speed. That's what brought on the shakedown to look for a problem.
It has always worn tires just fine with the factory setup until recently.
Old Feb 10, 2016 | 04:26 PM
Gville350's Avatar
Gville350
^The soft OEM bushings allow for suspension geometry changes during braking and cornering, thus leading to the inner tire wear. Well known problem alot of 2IS owners notice within 30k miles of ownership sometimes.
Watch this video showing the differences between a solid bushing vs the OEM bushing :
Old Feb 10, 2016 | 04:28 PM
Jeff Lange's Avatar
Jeff Lange
Keeping it Real
LH and RH are definitely different, so make sure you get one of each.
The parts are the same for AWD and RWD.
Jeff
Old Feb 10, 2016 | 06:37 PM
flowrider's Avatar
flowrider
Veteran: Air Force
I have a pair that came off my ISF when I upgraded to the RRRacing LCA Bushings. PM me if you're interested.
Lou
Old Feb 10, 2016 | 07:01 PM
Tungstn-IS's Avatar
Tungstn-IS
Yeah, I've read about that. But I'm at 120k miles now and it is just now starting to show the signs of weakness. I don't do any spirited activity with this car anymore, it's been relegated to grocery getter/commuter for me. I mostly drive my new Tundra on the weekends and have a dedicated car for the fun times. That's why I'm not really looking to upgrade, just fix it. This car has about served it's purpose for me anyway, surely getting close to an upgrade.
Jeff
Thanks, that's what I was looking for.
Lou
What is the difference is between the F and x50 units?
Old Feb 10, 2016 | 07:52 PM
flowrider's Avatar
flowrider
Veteran: Air Force
^^^^The ISF unit is a bit stiffer. Otherwise no difference.
Lou
Conceptvip
Jun 11, 2024 11:53 AM
wnyjazz
May 24, 2022 10:47 AM
Briannyc
Suspension and Brakes
Jul 19, 2013 05:47 AM
LudeNsoL
Sep 8, 2010 11:52 PM
NICKGS4
Feb 6, 2005 10:41 PM
