DRL Slim Decoder 06 IS350
Old Apr 28, 2015 | 10:08 PM
TLRD's Avatar
TLRD
Default DRL Slim Decoder 06 IS350
shoot me if I'm reiterating an old thread but has anyone found a reliable, safe and non melting slim decoder? All the threads I've found on here so far are years old..
Old Apr 29, 2015 | 01:37 PM
my1s250's Avatar
my1s250
I use the ijdmtoy one but there not slim but if you take off the cover they will fit inside the headlight cover, and I have been using it for 2 year now no problem
Old Apr 29, 2015 | 01:42 PM
getafewliv's Avatar
getafewliv
I got mine off ebay. $30 for the LED bulbs and decoders. First set they sent didn't work well enough and flickered. They sent out (at no extra cost) larger ones that have been problem free for over a year.
Unfortunately, I don't really have any useful info. Just that yes, you can get cheap working decoders that will (with patience) fit in the housing.
Old Apr 29, 2015 | 01:44 PM
pheonix72's Avatar
pheonix72
Same here. I've been using the same one and removed the covers to fit inside housing for almost 6 months now. I have to open the headlights covers to check if they are overheating.
Old Apr 30, 2015 | 11:43 PM
TLRD's Avatar
TLRD
Did you put the cover back on or are you leaving it off?
Thank you!
Thanks for the info. I'll think I'll order some if you guys aren't having overheating/melting issues!
Old May 1, 2015 | 06:27 AM
redspencer's Avatar
redspencer
OG Member
Veteran: Marine Corps
You can leave the covers off. Just cover the internals with heat shrink and electrical tape and you should be good to go!
Old May 1, 2015 | 08:05 PM
Raybean's Avatar
Raybean
I did the same thing and took the covers off. Works fine
Old May 2, 2015 | 09:14 AM
TLRD's Avatar
TLRD
You don't get any moisture or condensation inside the headlight leaving the covers off?
Old May 2, 2015 | 06:03 PM
redspencer's Avatar
redspencer
OG Member
I was referencing the covers of the decoders. You can remove those, cover the internals with heat shrink/electrical tape, and then stuff them inside the headlight. Your headlight covers should be able to close without any issues.
Old May 4, 2015 | 01:38 PM
getafewliv's Avatar
getafewliv
I believe some of them are built into a heat sink housing, I would not recommend using them without the heat sink.
Old Jun 16, 2015 | 07:44 PM
RU514's Avatar
RU514
How bad is the flicker without a decoder? Wasn't planning on using a decoder if you can't see the flicker from far away.
Old Jun 17, 2015 | 11:09 AM
pheonix72's Avatar
pheonix72
Some people said the flickering isn't that noticeable but i could not live with it. It was somewhat annoying especially when you drive behind cars with very reflective rears (i could only imagine how annoying it is for the people in front of me).
BTW, the decoder's housing from JDM do not serve any heat sinking purpose (just a simple plastic housing). It is better to safe and wrap it in high temp tape to protect the light housing. I actually checked my decoder after about 6 months of usage and no sign of over heating.
Old Jun 17, 2015 | 11:19 AM
RU514's Avatar
RU514
Thanks. Did a search and saw this.
Not sure if this is what others have noticed but the flickering without a decoder looks like a strobe light (not to mention a flicker even with the decoder).
Old Jun 17, 2015 | 11:35 AM
pheonix72's Avatar
pheonix72
Yes, it looks like strobe light up close. The measured the voltage put out by the decoder and it was around 14V (vs. around 6V from OEM DRL). My JDM decoders do not flicker at all (a good test is check it with another car's rearview camera (i.e. park behind another car with rearview/reverse camera) and you could see the flicker as it is extremely sensitive to flickering
samuelpm
Mar 1, 2018 05:45 PM
metaleckz
Jun 12, 2014 08:11 PM
jmorales91
May 20, 2014 11:52 AM
dannyboy26
Lighting
Feb 6, 2014 02:39 PM
