Throttle Body Removal
Old Mar 18, 2015 | 06:27 PM
WillK's Avatar
WillK
Default Throttle Body Removal
Hey guys, I've been home for six weeks now recovering from surgery and I'm bored!
I got the bright idea that I want to remove, clean and polish the TB.
I searched on throttle body removal but didn't have much luck. Anyone know how to remove the TB?
Any hazards or concerns with doing it? I'll probably try tomorrow or Friday morning.
Just wondering if anyone tried it yet...
Old Mar 18, 2015 | 06:34 PM
ianbis's Avatar
ianbis
haven't tried it yet but I did remove the engine cover to look at the engine when I first got her and it looks pretty straight forward, just be careful of the electric connections cause it looks like after heat cycling under the engine covers for awhile makes the electrical wires prone to pulling out of their respective plugs which will require re pinning the plugs and knowing which wire goes to which pin in multi pin/wire plugs, maybe take detailed pix before you embark on your adventure, it will make reassembly and your life in general much easier.
Old Mar 18, 2015 | 06:48 PM
WillK's Avatar
WillK
Thanks. Yeah, I looked at it when I first got it but haven't since. Can't remember if there's any coolant lines running through it.
Oh well, got three more weeks of no driving no working and a Dremel. Should make a good project.
Old Mar 18, 2015 | 07:25 PM
liqB's Avatar
liqB
There is a DIY posted on here for sparkplug change for the IS250.
When I changed my plugs removing the TB was part of the steps.
Best of luck!
Old Mar 18, 2015 | 07:30 PM
ianbis's Avatar
ianbis
step away from the dremel!! lmao
Old Mar 18, 2015 | 07:43 PM
WillK's Avatar
WillK
Best of luck!
Thanks! I'll check it out!
C'mon man, I gotta Dremel something! lol. That Dremel is calling my name!
Old Mar 19, 2015 | 06:05 PM
Gville350's Avatar
Gville350
^You can use the Dremel to polish stuff! Go for it!
I want remove my TB and install one of these behind it...if enough room :
Old Mar 22, 2015 | 09:13 AM
WillK's Avatar
WillK
Very nice! NOS plate! How much will you be spraying?
As for TB removal, I chickened out. It's very easy except I saw a vacuum connected on the lower left from front view and I was afraid the hose would fall down and be gone.
Anyone know what that is...? I'd try and disconnect from the other end if I knew what it was.
Old Mar 22, 2015 | 01:49 PM
liqB's Avatar
liqB
I believe its a coolant line
Old Mar 22, 2015 | 01:59 PM
WillK's Avatar
WillK
Great. I figured/worried there was a coolant line going to it. Oh well, just gotta trace it back to its origin.
AshyBone
GS - 1st Gen (1993-1997)
Oct 19, 2016 08:56 PM
WickedLex
Oct 13, 2007 03:09 PM
SC300_704
Aug 13, 2007 01:50 PM
BMJ
Jul 6, 2003 11:05 PM
