Jack stands all four
I found a good spot up front but not the rear. Im trying to replace my differential fluid this weekend and need to know where a good spot is. I tried the pinch weld but they bend.
I use my jack stands at the pinch welds, but turn them sideways and along the inside of the pinch weld. I tried using a block with a slot cut out, but that was more trouble than it was worth. If you feel under there, there is some plastic near the wheel well. I try to make sure I stay just off of that with my jack. There isn't a lot of room under there for a hydraulic jack and a jack stand. So the stand goes pretty close to the jack. If you use the jack that comes with the car, you should have more room.
tomtsops
May 20, 2008 12:54 AM
