Steering wheel keeps getting off-centered
Old 09-24-14, 10:02 AM
nitrotang
nitrotang's Avatar
Default Steering wheel keeps getting off-centered
I've had 4 alignments done within the last 5 months and my steering wheel keeps going off-centered. The first 3 times, the shop would align everything to spec, but within a week, the steering wheel would be at a 15 degree angle to the right to steer straight. The 4th time I brought it back to them in June, they said they found out that the upper control arm on the driver side was loose so they tightened that and it's been fine up until about a week ago. Now my steering wheel is back at the 15 degree angle to the right. is the alignment shop not doing something right or is there something loose in my steering/alignment setup?
On a side note, I also noticed after they tightened the upper control arm, whenever I turned at slow speeds/park or applied the brakes, the passenger side would make a creak and clunk sound. I checked underneath and my bushings are fine.
Old 09-24-14, 10:33 AM
jonathanz
jonathanz's Avatar
you should bring it to another shop and let them check all your balljoints see if they're okay, maybe some arms are bent?
Old 09-26-14, 12:01 PM
nitrotang
nitrotang's Avatar
I brought it to another shop where I go for my oil changes and they jacked up my car and knocked against the wheels and ball joints to see if they could hear any of the sounds I described, but there was nothing.
Old 09-26-14, 12:52 PM
Sffd103
Fire Slayer
Sffd103's Avatar
Could your steering wheel not be tightened on completely? Just a side thought.
Old 09-26-14, 08:06 PM
skottydznt
skottydznt's Avatar
somethings loose for sure. I'd take it to another shop for another look over.
Old 09-27-14, 07:30 AM
nitrotang
nitrotang's Avatar
I called the shop and they said they would take a look at it again free of charge. I'll double check with them about the steering wheel not tightened.
Old 09-27-14, 05:33 PM
sjgIS350
sjgIS350's Avatar
steering wheel not tightened? Uh..not likely…
Steering wheels mount on a shaft that has splines so it can't 'move around'..If it was loose it would move in/out (towards the driver) not side to side..
Old 09-27-14, 06:50 PM
Gville350
Gville350's Avatar
Front cross-member loose?
Old 09-30-14, 05:43 PM
nitrotang
nitrotang's Avatar
I got the car back from the shop and they said they tightened the passenger upper control arm. The 3rd time I went in for a re-alignment, they only tightened the driver side (don't know why they didn't tighten both of them at the same time). The steering feels a lot "stiffer" and when going over bumps, my steering wheel won't go left and right as loosely as it did before. That seems to have solved the problem.. hopefully.
LS430Lexus
01-18-20 11:47 PM
pandatroop
01-24-17 06:28 PM
muifast
LX - 3rd Gen (2008-2021)
08-10-12 04:22 AM
newpuy
05-11-10 08:00 AM
Quick Reply: Steering wheel keeps getting off-centered
