2IS dash removal process
Old Aug 3, 2014 | 10:00 PM
robdog's Avatar
robdog
Default 2IS dash removal process
hello everyone i have this dash that has all these chips in it and i got a new one here is the process of taking it out. this is the new one
first things first center console needs to come out
rear seat vent needs to come off
next bolts in front of the cup holder
diagram for depressing clips.
sorry for the blurry picture
Old Aug 3, 2014 | 10:04 PM
robdog's Avatar
robdog
Old Aug 4, 2014 | 12:26 AM
BoyOhBoy's Avatar
BoyOhBoy
Thanks for the guide. Won't be needing this probably but still a good reference. So you need to take off the steering wheel just to take off the dash?!
Old Aug 4, 2014 | 12:27 PM
Gville350's Avatar
Gville350
^I think he is still in the process of creating the thread and adding pics!
Old Aug 4, 2014 | 08:06 PM
robdog's Avatar
robdog
Old Aug 4, 2014 | 08:25 PM
Sceanzo's Avatar
Sceanzo
You can leave the steering wheel on. Just drop the entire column and leave it in the floor.
Old Aug 4, 2014 | 08:36 PM
RDIS250AWD's Avatar
RDIS250AWD
good write up, hopefully you finish it bc I will need to remove my dash here within the next month or so for a project I've been lazy to tackle
Old Aug 4, 2014 | 08:38 PM
robdog's Avatar
robdog
with a trim tool pry the side cover off. also on passenger side
this then can be popped off and connections disconnected
the steering column cover will come off with the cluster trim. the cluster will then have two screws at the bottom and there are two clips that holt the top in. the bottom will come out first.
the next four are locations for knee air bag bolts and the same applies for the passenger side knee air bag but there will only be three. one on the console side and two at the door side
this bottom trim will come off with two screws . the passenger side will be able to pry downwards and the ambient led light will be able to be un plugged also on the drivers side the DLC connector will be able to pop out
this is pretty easy. depress two clips and pull carefully
just pry curtain A piller cover off
this is the hook that holds the cover on. take long pair of needle nose pliers and twist 90 degrees and it will come off
glove box about to come out
there will to two blots on the top side and there will be 3 along the bottom
4 bolts under the head unit (10mm)
if you've ever done this before you know you need to be very carful when pulling this out.
to hold the front of the dash on there are six bolts and one nut. the nut will be behind where the cluster was and it will have a locating bolt that goes through the dash to help line it up. also where the glove box was above there will be a cross rod or pole that has flanges welded to it that will connect the bottom of the air bag this will help with loosening the dash up so it can be pulled out
Old Aug 4, 2014 | 08:40 PM
robdog's Avatar
robdog
after all bolts are out the dash should just pop out and it helps to roll it towards you. two people also makes removing it easier
Old Aug 4, 2014 | 08:47 PM
metaleckz's Avatar
metaleckz
How long did it take you?
Old Aug 4, 2014 | 09:48 PM
robdog's Avatar
robdog
about 4 hours i was going pretty slow tho
Old Aug 4, 2014 | 11:04 PM
rawr2is250's Avatar
rawr2is250
Great write up. marked for future reference.
Old Aug 5, 2014 | 12:07 AM
BoyOhBoy's Avatar
BoyOhBoy
Damn, all those chips are scaring me. I just bought a sun shade so I hope it's enough..
Old Aug 5, 2014 | 12:14 AM
Kentchup's Avatar
Kentchup
this is a great write up, my friends car has the same chips in the places in your old dash. This will def come in handy when he gets a new dash.
Old Aug 5, 2014 | 09:31 AM
NYKnick101's Avatar
NYKnick101
This is what I needed. I need to get my old busted dash out because mine looks just as bad as this pic
