temp gauge
Old Apr 16, 2014 | 04:22 PM
lexus-is2's Avatar
lexus-is2
Default temp gauge
I did a coolant change few days ago with new toyota SLL coolant. Today i noticed something new which I never experienced before. Temp gauge was at usual just below the half way mark. I accelerated quickly for a few seconds after which i quickly glanced at the temp gauge and noticed it actually went down a little and then after 10 or so seconds it went back to the normal below the half way mark.
Never experienced this before. Has anyone experienced such a thing?
Old Apr 16, 2014 | 04:35 PM
pheonix72's Avatar
pheonix72
I wouldn't be too worry about it. The radiator might got a rush of fresh air and cooled down a little bit.
I would be more worry if the temperature is higher than before since it means you might have some air bubbles in the coolant system.
Old Apr 16, 2014 | 05:05 PM
NYKnick101's Avatar
NYKnick101
Thats actually what your car is supposed to do, it mean the coolant is flowing well and lowering engine temperature. If you use aftermarket low temp thermostats, it becomes more noticeable. You should only worry if your gauge gets hotter/goes up instead of going down. You can never be too cool... PUN INTENDED!
Old Apr 17, 2014 | 01:36 PM
Gville350's Avatar
Gville350
I'd blurp the system to remove any air bubbles.
jacksonman
Nov 3, 2018 07:09 AM
lexus-is2
Jul 16, 2013 01:35 PM
mjes300
Aug 5, 2009 05:40 PM
indypwr
May 8, 2004 08:33 PM
Jmai22
GS - 1st Gen (1993-1997)
Dec 13, 2002 07:27 PM
