Looking at a few rims, need some feedback/advice
Hello CL,
So I've ventured off into the many Wheel threads across the forum and have decided on a set of Varrstoen ES7 for my IS250.
I recently upgraded my brakes to the OEM factory IS350 and have found it some what difficult to find the proper wheel style to fit without going too crazy with the offset/tire stretch game.
So I've come across the following sizes and I'm kind of in a perdicament and would like some guidance. I've been interested in 18x9.5 +22 and 18x10.5+22 for this set of wheel (don't ask me why, but it just seems like a conservative offset and width, correct me if I'm wrong). I've been told by the vendor that in order for the fronts to fit properly I will need atleast a 3mm spacer to clear the factory brakes OR I can get an even more aggressive offset like +12 which I don't really want to do because I want very minimal stretch when i get new tires.
My fendors are already rolled and pulled so I'm not afraid of doing more work as needed. From what I understand I'll need to also shave or mod my bumper tabs which is also fine. My main concern is stretching a tire as I DD this car about 70 miles a day and want something to fit reasonably speaking.
I'm open to any other style of rim that will clear the IS350 front brakes with conservative offsets as well, so I'm not really stuck on this particular rim but the price is mainly why I've been eye balling these rims. Any guidance would be appreciated.
With my coils on I'm currently about 1 finger gap in front and no finger gap in rear on the OEM 18's, just FYI.
Hello CL,
So I've come across the following sizes and I'm kind of in a perdicament and would like some guidance. I've been interested in 18x9.5 +22 and 18x10.5+22 for this set of wheel. I've been told by the vendor that in order for the fronts to fit properly I will need atleast a 3mm spacer to clear the factory brakes OR I can get an even more aggressive offset like +12 which I don't really want to do because I want very minimal stretch when i get new tires.
The only thing you could do to not stretch tires (much) would be too add camber, with arms, or to widebody/pull fenders a lot. None of which are really good for a daily driver either.
I highly do not recommend stretching for daily driving. For that particular setup you would want to do a 225 and 255 setup. That is by no means a huge stretch but it is still stretched. Maybe take a look at linea corse wheels at wheeldude.com. Nice wheels with decent offsets to run the proper tire.
There's really no way around it besides for stretching tires, at least for those kind of offsets. All the fender work and tab relocations are necessary in addition with stretching tires.
EDIT: The vendor recommended me go with +30 offset in the rear instead of +22. Would this look weird as my fronts will be +22 (more like +17 when I get the 3MM spacer to clear brakes)? It would seem the fronts would be more aggressive than the backs which I was under the impression the backs are typically more aggressive due to more room to work vs the front. Thanks.
18x9.5 +22F
18x10.5+22R
the following tire sizes would be ideal;
225/40F
245/40R
Would the 245 in the rear be considered to be noticeably more stretch than the 255 you recommended?
I've heard a lot about tire side wall (narrow vs wide) what does this exactly mean and what brands of tires are best suited for stretching? Again, I'm trying to make my rims look like theres not much stretch to begin with.
EDIT: I plan on being low maybe a finger gap or less all around.
fgpalmer71
09-05-13 10:31 AM
stylistic
Wheels, Tires & Brakes Forum
02-24-10 11:45 PM
