Door Lock Actuator. Help.....
Old Nov 1, 2013 | 10:08 PM
chadster's Avatar
chadster
Default Door Lock Actuator. Help.....
So the door actuator fix was going great until a few Springs popped off and now I have no idea where they go. Can anybody help me with a picture? I'd rather not have to buy an actuator on eBay for $150
Thank you in advance for any help. It will be much appreciated.
Chad
One of the springs has my finger pointing to it and then the other one is still a little bit to the right from that yellow circle in the middle. It's the spring with the hook on it and a long arm.
Old Nov 2, 2013 | 05:07 AM
quick123's Avatar
quick123
Toyota/Lexus will not have a diagram of the internals...I just checked and it only shows the part as a whole, not opened up.
Your best option is to take another door lock actuator out and open it up to see how everything is attached. That is how I was taught to do drum brakes, only one side at a time so you can check how all the springs and clips are attached.
GL
Old Nov 2, 2013 | 09:40 AM
carlos3366's Avatar
carlos3366
Default i can't believe lexus uses plastic parts
for high wearing moving parts.
Old Nov 2, 2013 | 09:45 AM
chadster's Avatar
chadster
Thanks for the advice. I have to decide if I want to give that a go or not.
Old Nov 2, 2013 | 09:52 AM
quick123's Avatar
quick123
Every brand does...and it is not the plastic that fails, it is the electric actuator that fails over time
Old Dec 31, 2013 | 11:41 AM
Barny's Avatar
Barny
Default Spring location
Hi Chad, I'm in the middle of the same repair on my 2007 IS350. The actuator is similar to yours, but not exact. The "Y" ends of the 'finger' spring photo engages a pin underneath and on the large white plastic lever. It should be 20mm left of the lever's main shaft, about where there's a tiny hole in yours. The spring circle end snaps into a peg on the black housing.
Bruce.
Last edited by Barny; Dec 31, 2013 at 08:06 PM. Reason: adding more detail and hopefully a photo
GS3KID
Mar 27, 2014 06:28 PM
69charger
Dec 3, 2012 06:45 AM
Dx3
Jan 11, 2005 09:22 PM
Dx3
Oct 28, 2004 04:24 PM
