Questions on VAIS Sirius install
Hello fellow 2isers,
I recently picked up a used Vais SLS2 with SCC1 tuner for the long distance travel I've been doing, I'm planning on doing the install by myself and have read several threads (removing the head unit, installing the vais adapter, installing the shark fin adapter), etc. to help with the process.
Just a couple quick questions:
Im going to purchase the shark fin antenna adapter from Vais. Do you need to remove the rear seats to run the cable to the trunk?
Can anyone recommend a set of a trim removal tools so I won't destroy my dash, vents, and other trim pieces?
Thanks in advance!
Thanks in advance!
The Godfather
Feb 16, 2008 04:57 PM
