Quick consult for IS350 potential issue prior to purchase
2006 IS350 68,000 miles
Purchasing 2006 IS350 68,000 miles today but concerned on:
Twice it started (but with a few starts OK) with a bit of a crackling sound, more of a knock, in about 1-2 seconds and it goes away. Will send to my mechanic today for consult.
Anybody familiar with this issue? What could this be?
Otherwise the car is in good shape.
Your quick help is very much appreciated!
Mandy
PS: The car is for my daughter. I want one for myself...!!
Mandy
Just went to my mechanic and describing what's happening it is probably the starter. Sometime later, the starter will probably act up, that's a $600 repair. I will have to consider this when the purchase goes through. And yes they do tick a ton!
I have an 06 and i heard that noise quite a few times when I would start the car so I think know what your talking about. I could have sworn it was the starter so I put it on the lift but couldn't hear any noise under the car or around it. It was the dashboard or something under it because when the levers go all the way back and forth i heard it. I heard it even when it didn't start all the way. Car kept on starting and driving fine though
Does this only happen at cold start? If you do a search there's a recall on the rough start. Its actually the cam rattle. When the car is cold or has sat long enough, the oil drains out so the cam rattles on startup, after a few seconds there's oil and it no longer rattles. It doesn't do any damage to your car but it just sounds bad.
I would still use this as leverage when buying the car though
All, it is called the notorious "cam rattle". You can search this phrase online here and find threads about this. Basically the weights within the cam gear become un-lubricated while sitting idle for hours (especially in the hot sun) and upon cranking over it will "rattle" or "grind" for a second. The best advice I'd have is to switch to a full synthetic motor oil (Mobil 1) as the oil with protect the metal better and will tend to "stick" to the metal long/better than conventional. On my '06 350 I've heard the cam rattle about 10 times during it's life with me (owned since 31k miles, now at 68k). Now, the dealership says they have a "fix", but that is to replace the cam gears themselves. BUT, I've read online about others that have had this "fix" done and later on started experiencing the same thing all over again.
As of right now, I've not read about a cam rattle leading to motor failure or cam gear failure.
Enjoy the 350 and indeed get yourself one too! You won't regret it!
Thanks again guys and if the sale goes through, I will be in this great forum as well.
Mandy
Or maybe own a 350 soon...
The only 2 showing open on the Lexus Owner's website are the Wiper nut and Trunk Latch issue. I assume the recalls were completed on this IS350. I am reviewing the service history and some TSIB numbers are spelled out. Glad to know that the cam gear issue is the source of the noise and not a potential starter replacement issue.
Annoying but acceptable noise if nothing will result in a non-start situation. Again we do not the princess to raise all kinds of rant...LOL.
