Staggered setup
I normally only stay in the classified section, so if im in the wrong place can the mods please move? Thanks in advance.
So I was planning on getting a set of linea corse lemans and i just heard something interesting: apparently running a staggered setup on an awd ruins the car somehow. Anyone a little more informed in the matter that can help me? And if what I heard is true, is the alternative of spacers any better? Thanks guys!
Current car: 2007 is250 AWD
-James
-James
If you chose the wrong size tire that throws your rolling diameter off yes. Your only allowed 1% difference from stock rolling diameter. If you wanna play it safe then just get the same size all around and add the spacer to the rear to give it a poke. Then your still be able to rotate your tires front to back.
^what he said. Many of us have done it. Both my winter and summer sets are staggered
https://www.clublexus.com/forums/is-...er-thread.html
usually on AWD cars running staggered will stress the diff and cause damage in the long run. there were many threads on it when i was in the AWD world when i had a subaru. i know its apples to oragnes, but the general idea is the same
you can use the tire diameter calculator
http://tires.tirerack.com/tires/Tire...r%20Calculator
Do a search and you'll see a lot of discussion about AWD staggered setup.....
I wouldn't run staggered... I researched this fourm before I did mine, and after listening to everyone I did a 19x8.5 and 19x 10 set up with BC COILS. It was going good for about 20k miles, but than my transfer case blew and I had to get it replaced not covered under warranty ($4500). Before that I was tearing CV boots quite frequently.
To each his own though.. I wouldn't advise it though!
so ive decided to get 19x10 all around to avoid any unnecessary wear. better safe than sorry.
anyone know what offset to get with these wheels to have the wheels flush with the rear wheel wells?
Thanks... I was running Staggered til that **** fuked up my car!! 19x10 bro?? Hope ur planning on making any U turns in that car.. ur gonna need mad fender work!
It's all about the offset fellas. He can run 10" width with the rite offset without over doing his fenders. Remember your still limited to the tires size. Even tho your running square set up still has to be close or under 1% diameter.
So I dont know anything about offset at all to be honest.... what offset is recommended for 19x10 linea corse lemans to have the wheels flush with the back fenders? Thanks again for all of the help guys!
