IS250 Headlight Loose part inside...Please Help!
Old May 29, 2013 | 01:02 AM
vncasanova's Avatar
vncasanova
Default IS250 Headlight Loose part inside...Please Help!
Hi guys, can anyone please help me with this problem. I'm so confused as to how this happened. Today I went out to wash my car and noticed the headlight on the driver's side had a loose piece where the turn signal is. I have no idea how that happened as I did not touch anything near there. Can someone show me how to push this loose piece in place? Thanks, guys
Old May 29, 2013 | 05:24 AM
B16da9's Avatar
B16da9
Since I've retrofited both these and LED headlights I can tell you that the only way to fix that is to open up the headlight and pop the piece back in place. I would also use a small drop of clear apoxy to make sure it does not happen again.
Old May 29, 2013 | 06:32 AM
lysis250's Avatar
lysis250
If your are still under warranty go to the dealer and have them fix it.
Old May 29, 2013 | 06:36 AM
whitebeast's Avatar
whitebeast
You have to open up the headlight to fix it or stop by at dealer ship if you under warranty
Old May 29, 2013 | 06:50 AM
B16da9's Avatar
B16da9
Thanks for pointing that out guys, I tend to forget about warranty as I rather fix things myself than let those monkeys at the dealer touch my car.
Old May 29, 2013 | 07:28 AM
pmanliu's Avatar
pmanliu
+1, dealer would most likely just give you a new headlight too if you're under warranty. Sweet
Old May 29, 2013 | 11:40 AM
vncasanova's Avatar
vncasanova
sadly, my car is 90K miles already, i dont think it's still under any warranty
Old May 29, 2013 | 11:51 AM
B16da9's Avatar
B16da9
Then you have two options, fix it yourself by opening up the headlight or buy a new headlight.
whitebeast's Avatar
whitebeast
have you try to call lexus customer services? They may help you out
Old May 29, 2013 | 11:53 AM
vncasanova's Avatar
vncasanova
that's what i'm afraid of.....maybe it's time to switch to led headlight
vncasanova's Avatar
vncasanova
Thanks everyone....
Old May 29, 2013 | 01:10 PM
lysis250's Avatar
lysis250
Well if you bought your car as a Certified Pre-Owned then the warranty gets extended to 100K miles.
Old May 29, 2013 | 04:11 PM
vncasanova's Avatar
vncasanova
unfortunately i bought the car new, guess i'm stuck with it or get a new led headlight
Jbreezie
May 5, 2017 06:56 PM
iDriveAs2k
Jun 1, 2016 08:05 PM
Madnesz
Aug 15, 2013 08:57 PM
Todd
RX - 1st Gen (1999-2003)
Jul 29, 2002 04:37 PM
