Water Pump Question
Old May 24, 2013 | 02:03 PM
vicsis250's Avatar
vicsis250
Default Water Pump Question
So I took my 08 IS250 with 53000 in for oil change service to the lexus dealership everything was find until my SA told me that next time around they are going to have to possible replace my water pump because according to her its seeping? What the hell does that mean? I asked her if it was ok to drive she said yeah no problem car is running great and while we are in their we will also fix the carbon problem. My question is if my water pump is seeping why not keep the car and just fix it now instead of letting me drive away is it really not a big deal yet? What should I look for car does not over heat always normal temp. And advise would be great.
Old May 24, 2013 | 05:43 PM
RDIS250AWD's Avatar
RDIS250AWD
Seeping means you got a small/slow leak. Did u notice a leak? If you're really concerned I would schedule an appointment asap to get it fixed.
Old May 24, 2013 | 08:31 PM
jnguyenyo's Avatar
jnguyenyo
I would fix it on the spot..might be a minor seep if theyre putting it off?
Old May 24, 2013 | 08:44 PM
racerboi07's Avatar
racerboi07
i doubt its bad at 53k miles. have another dealer look at it to see if they say the same thing
Old May 24, 2013 | 10:00 PM
laobo979's Avatar
laobo979
I'm guess you don't know about the major issue with water pump failure on these car. It happens often and at lower miles than you think. My GF replace at 40k and just two weeks ago at 80k. Can you drive with a slow leak yeah. If they tell you to come back and your still under power train warranty don't worry. If any thing seize up you'll get a fully built new motor.OP just make the appointment to have it fix so they have the parts ready to install. It takes a few hrs.
Old May 25, 2013 | 06:46 AM
carlos3366's Avatar
carlos3366
its under warranty, just have it replaced right away.
Old May 25, 2013 | 10:56 AM
vicsis250's Avatar
vicsis250
Thanks you guys I was thinking the same thing I knew about this problem with this model car their has never been a leak that I have seen and I park it in my garage it must be something very small if not my SA would have made me leave me car. Either way I'm taking it back at the end of the month to get that taken care of.
thaeleelyr
RX - 1st Gen (1999-2003)
Oct 24, 2015 10:10 PM
kur1j
Nov 5, 2014 10:54 AM
Ants350
May 15, 2014 11:56 AM
Colpup ES3
Nov 9, 2007 04:26 PM
paul1234
Performance
Sep 26, 2001 09:50 AM
