Possible Major Engine Problem (<60k)
Ok, Lexus is handling the bill. They've apparently never seen something like this before. The guy told me that the VDT gear came loose (or a screw holding it in?). It seemed to have then cause some internal damage to the camshaft, piston and/or valve. Anyway, it sounded bad. But since they are covering everything, I'm happy!
If there is any chance you can get verification on the specifics of what actually "let loose" we all will be forever greatful! If it is as simple as making sure something is torqued properly, I would love to ensure mine is prefect!
Question, have you had ever previously had Lexus perform the "cam rattle" TSIB on your car?
Thanks!
Thanks!
Of course - I will post the full update once I get it. As for the cam rattling recall, I'm not sure. If it was a required or recommended TSB, then yes, as I've had all of the TSBs done.
Car has 58k or so. Thanks!
WHat ended up getting replaced?
By what the OP said on the bottom of the first page, it makes be believe a bolt from the VVT cam gear came loose and started bouncing around everywhere causing issues. Well, we currently have a recall out to fix this issue...in fact, my '06 IS350 is going in under the knife tomorrow for it.
Yes, OP here - it's been a little while now. Some kind of loose bolt was the cause, but it ended up causing a loosening of the camshaft, which bent some of the valves. Everything damaged was replaced by Lexus for no charge (it was out of warranty), so I was pleased with the response.
lymlyt
Dec 15, 2016 06:04 PM
