Lock not working!
Old Apr 19, 2013 | 03:28 PM
NYG's Avatar
NYG
Default Lock not working!
Hey guys,
So my remote lock and exterior black-button door lock work fine, except for the drivers side rear door! I tried everything including switching on/off child lock, manually unlocking then locking, etc..
Any suggestions other than taking out the door panel and seeing whats up? Anyone have this issue? It doesn't work from the remote, internally, or from the black button exterior lock. all other doors work fine. It doesn't even lock if it's left unlocked which is safety issue for me.
Old Apr 19, 2013 | 03:52 PM
felo2081's Avatar
felo2081
The door panel it's very easy to pull out, my boy's driver side wasn't locking either and we took it apart it was a clip that came loose! YouTube it!
Old Apr 19, 2013 | 04:43 PM
NYG's Avatar
NYG
Thanks for the heads up, I'll check it out if it comes down to it. As for now, does anyone know if it can be a fuse? Or is it all one fuse?
Posted from ClubLexus.com App for Android
Old Apr 20, 2013 | 04:54 AM
NYG's Avatar
NYG
anyone else?
Old Apr 20, 2013 | 05:35 AM
Sffd103's Avatar
Sffd103
Fire Slayer
Most likely not a fuse since the rear of them work. You could have a frozen door locking mechanizm.
Old Apr 20, 2013 | 07:36 AM
NYG's Avatar
NYG
Can anyone post a video or how to guide on how to remove the REAR door panel on a 2is? and how to check the locking mechanism?
Old Apr 20, 2013 | 11:07 AM
Clay Easto's Avatar
Clay Easto
Both of my rear door lock actuators went at different times. Repaired under my extended warranty.
Old Apr 20, 2013 | 06:07 PM
NYG's Avatar
NYG
UPDATE:
I now have noticed that the power window from the driver control panel does not work for the same rear passenger side that I'm having locking/unlocking issues with. So, again- the problem door is the rear passenger door. It does not lock/unlock from anywhere (remote, black external button, interior power lock) AND the same door's window will not go up/down from the driver's control panel (but it will on its own panel).
Any suggestions anyone? This is really weird...I took out the door panel today and the ball/hook cables seem to be connected fine. could it be the actuator for sure now? or could it be a fuse?
Old Apr 20, 2013 | 07:12 PM
NYG's Avatar
NYG
anyone? I'm really stumped and really dont want it to be the actuator. How do I check if its a fuse? will both rear doors go at once?
Tjord
May 1, 2019 07:14 PM
Orozco27
Aug 4, 2012 02:32 AM
DixonPai
Dec 28, 2010 11:16 AM
lv6l
Apr 5, 2010 11:35 PM
kevs
Apr 28, 2002 06:55 AM
