need help with wheels!
Old Apr 16, 2013 | 03:58 PM
IS3fity's Avatar
IS3fity
Default need help with wheels!
I'm ordering Varrstoens es2 for my 350
still deciding on what size!!
The shop has
18x9.5 +30
18x10.5 +30
19x9.5 +30
19x10 +35
in stock..
anyone running one of these setups?
I'm worried about the front brakes clearance and I don't wanna fold the rear fender!
any thoughts or concerns?
Thanks in advance
Old Apr 17, 2013 | 01:04 AM
AK-47's Avatar
AK-47
it come down to what tires size u want.
Old Apr 17, 2013 | 04:11 AM
Offspring's Avatar
Offspring
Well I had the ES 2 19x9.5 +30 and 19x10.5 +30. Was running 235/35 and 265/35. Lowered on bc coils 1 finger gap.
Keyword is had. I didn't feel comfortable hacking up my lexus. The fender tab mod and the liner rubbing was not my cup of tea. Also the Es2.2.2 won't clear the is350 brakes with a +30 offset.. I ended up getting a 10 mm spacer which gave me a +20 offset, allowing me to clear the front calipers. You will have to roll the front and rear fender and possibly run negative camber.
I sold the wheels. It was not worth it to me to go through all that. Good luck to you. If u do decide I have the 10mm spacer for sale in the classifieds section.
Old Apr 17, 2013 | 04:55 AM
bob4256's Avatar
bob4256
Too many factors are involved that your not telling us. Are you dropped? Slammed? Do you want to tuck tire/rim? Do you want to do fender mods? Do you want 18s or 19s?
rI cant comment on brake clearence, but depending on how low you go you may need to roll your fenders
Old Apr 17, 2013 | 05:37 AM
Sffd103's Avatar
Sffd103
Fire Slayer
You will most likely need to modify your fenders and quarter panels with those offsets. Especially if you want to be low. If you don't want to touch the body you'll have to go with an offset of +40
Old Apr 17, 2013 | 01:51 PM
projectdna's Avatar
projectdna
stay away from varrstoen wheels if you don't want to touch your fenders at all.
Old Apr 17, 2013 | 06:47 PM
Offspring's Avatar
Offspring
they offer really aggressive offsets. as for quality they have gotten decent reviews across multiple forums.
Old Apr 18, 2013 | 08:07 AM
ZNation's Avatar
ZNation
I just put on 18" ES1s
18x9.5 +30 F
18x10.5 +30 R
Tires are 245/40 and 265/40
Slight rubbing of fender liner in front on tight turns...eventually tire will just rub itself some space im told.
Had to have the rear fender rolled. Since it was rolled, no rubbing at all.
Brake clearance was fine.
Old Apr 18, 2013 | 08:35 AM
Offspring's Avatar
Offspring
18x9.5 +30 F
18x10.5 +30 R
are you lowered at all ? The ES1 is a high disc wheel compared to the ES 2.2.2.
Old Apr 18, 2013 | 09:05 AM
ZNation's Avatar
ZNation
Lowered a bit. Not slammed by any means
Old Apr 18, 2013 | 09:34 AM
projectdna's Avatar
projectdna
18x9.5 +30 F
18x10.5 +30 R
the reason it rubs in the front is because you should've gone w/ 35-series tires instead of 40-series.
also, you should've gone w/ 35-series in the rear as well.
Old Apr 18, 2013 | 10:39 AM
ZNation's Avatar
ZNation
Agreed, I'd change that up next time i need tires...but its fine for now.
Old Apr 22, 2013 | 12:25 AM
IS3fity's Avatar
IS3fity
Thanks a lot everyone
nomz09
RC - 1st Gen (2015-present)
Jun 15, 2017 01:58 PM
02msmg3
Jul 23, 2012 06:08 PM
ohiois350
Feb 1, 2012 11:15 AM
Jaylex
Feb 4, 2009 04:35 PM
sinistervr
Dec 3, 2008 07:14 PM
