Interior lights stopped working
Old Mar 13, 2013 | 11:45 PM
lysis250's Avatar
lysis250
Exclamation Interior lights stopped working
Hello I just had went to my car to get one of my books out of it and my interior lights and the lights under the mirrors and the light that's on in the feet area stopped working. I have a 2008 Lexus is250, could it be that the fuse just burned out or is there something more major than that.
Old Mar 14, 2013 | 12:22 AM
Sango's Avatar
Sango
Check the fuse.
Seems like Fuse 9 went out.
http://drivers.lexus.com/t3Portal/do.../sec_04_03.pdf (page 331)
FUSE / Ampere / Circuit
9 / DOME / 10A / Interior | lights, meter
Old Mar 14, 2013 | 09:28 AM
lysis250's Avatar
lysis250
Can it be because I swapped out my original dome lights with LEDs?
Old Mar 14, 2013 | 09:30 AM
jbone29's Avatar
jbone29
i have the same problem also. i swapped to Putco led interior lights and my visor lights do not work at all but my dome lights shine like the sun though.
Old Mar 14, 2013 | 10:32 AM
RebulRigo's Avatar
RebulRigo
Did the LED lights every work? Meaning.... once you put them in....when you tested them, they worked fine and only now stopped working?
Alot of times, since the LED lights are fairly cheap, the slightest movement will make them go off. I would suggest moving the bulb around, maybe switching the positive and negative sides.
Old Mar 14, 2013 | 10:57 AM
lysis250's Avatar
lysis250
Yes I tested them and they worked fine. I installed them about a week or so ago and they worked like a charm. Just yesterday my lights stopped working. I'll check the fuse later on if it burned I'll obviously replace it, but would you guys recommend removing the LEDs and putting the stock bulbs in?
Lakersfan
Lighting
Apr 19, 2021 02:25 AM
05RX330AWD
Apr 22, 2017 01:23 PM
GilIS250
Aug 12, 2012 02:03 AM
reck0n
Jan 12, 2012 08:43 AM
Extreme437
Lighting
Nov 25, 2007 12:18 PM
