Handkook V12 tires question
Old Feb 20, 2013 | 01:05 AM
isbbq's Avatar
isbbq
Default Handkook V12 tires question
im using handkook v12, my car lowered and eating inside the tires. i want to know can i unmount the tires and switch left to right to use??? is inside and outside same??? thanks!
Old Feb 20, 2013 | 05:28 AM
Kumar350's Avatar
Kumar350
Yes the Handkook Tires are "flippable"
Old Feb 20, 2013 | 09:29 AM
isbbq's Avatar
isbbq
Thanks
Old Feb 20, 2013 | 11:05 AM
UniSlayEX's Avatar
UniSlayEX
You dont want to flip them if the outer tread will be worn out though, you should be "flipping" them regularly. Its more of a pain but the life is extended if that is what youre trying to achieve.
Old Feb 20, 2013 | 04:54 PM
Toxicxk23's Avatar
Toxicxk23
Get your front toe zero'd out as much as possible to help with the inner tire wear! Factory toe setting is very aggressive toe out which eats up the inner block tread of your tires!
Old Feb 20, 2013 | 09:37 PM
TUNG's Avatar
TUNG
I thought the hankooks are only one way directional? I tried to flip mines but they can't because I hve one direction.
Old Feb 20, 2013 | 10:19 PM
jdmSW20's Avatar
jdmSW20
i was just about to say the exact same thing. when the toe is too far off, it eats tires faster than camber wear will
Old Feb 21, 2013 | 06:28 AM
nonford's Avatar
nonford
They are a directional tire, look on the side wall and follow the arrows....and to flip them, you would have to dismount them and remount.
Old Feb 22, 2013 | 11:58 AM
Jetfire's Avatar
Jetfire
Royale with cheese
You're thinking of rotating. Flipping means removing the tire from the wheel and mounting it on the opposite side wheel.
Old Feb 22, 2013 | 01:11 PM
509IS350's Avatar
509IS350
Yes you can flip them left to right and right to left. I've had them done about 3 weeks ago at discount tire for free since I got them there. Plus my buddy works there and I only trust him to do it without messing my car/rims up.
SNiiP3R
Wheels, Tires & Brakes Forum
Jul 29, 2009 12:32 PM
MotoX
Apr 25, 2009 01:14 PM
areukhmer
Jan 31, 2009 01:08 PM
njmurvin
Sep 19, 2008 11:03 AM
PERRYinLA
May 4, 2005 05:12 PM
