Please help!!!!!!
Just for particularly ignorant people, power train could be used as a synonym for the terms engine and transmission. And if your limited mental capabilities prevent you from interpreting what I just said, let me oversimplify it for you: It's the same thing.
It's cool, English is not my first language either. In any case, the simplest way to solve your issue would be to take it to the dealer. As I stated earlier it is a power train issue (including but not limited to engine and transmission). Go to the dealer and state that you suspect a possible carbon build up. Don't say anything like "I tried to fix it on my own" because it could possibly ruin your chances of getting a free repair because dealers want to make money too. They should then inspect the car and provide you with a loaner/rent car for however long your car is stuck in the dealer. They WON'T charge you or at least they are NOT allowed to charge you without your consent to repairs but theres a high chance that the repair is gonna be free. (In fact it is most probably going to be free but you must be ready for the worst case scenario).
Finger cross!!
Many thanks!!!
*you're*
Thanks for understend!! So today i called to the dealer and talk to sevice guy! Hopefully i was explaind my issue!! Appoitment book on thruesday ! They will take my car for investigation for free,but he said it is posibility to charge for any repair !!
Finger cross!!
Many thanks!!!
Finger cross!!
Many thanks!!!
Of course. And also you could bring up the warranty argument regarding payments. If you feel like you're being ripped off, call local repair shops and see how much they charge for repairing whatever issue your car is diagnosed with. Make sure the quality of repairs is high as well (although I personally would rather stay with Lexus but I'm not sure how the quality of labor is out there in UK).
Thanks!!
But he has 107k, isn't that over the mileage that is set by the power-train warranty?
Thats the original warranty with the car. If Lexus sent you a letter about the CSP you would know that the CSP warranty for the carbon build up issue is 9years/unlimited miles extended warranty. Of course you wouldn't know that unless Lexus mailed you a letter or you talked to a Lexus SA.
Last time when my Is was in dealer they upgrade software and tell me my car is fix!! In fact after that was beter only 50% !! After cleaning throttle also was some change in engine works!!
Now if i drive on manual mode on 3 th gear 3,5k rpm and take of foot from acceleration pedal rpms drop to aroud 1,5k then suddenly jump to 2k and continue dropping!!
All my issue happend suddenly when im driving--
Deep engine sound ( like under high load on 6th gear and low speed in manual transission)
Also is oil consumption
When i look under the car on exhaust just behind the lambda sensors is like two bigger size of exhaust pipe! When im knock in one sounds as the empty glas of wine! Second sounds as full glass of wine! Can this be block and create this issue???? Im live in UK and not sure my problem will be sort out for free!! ???
Delays in acceleration on high speed ( tranny seems to think what shuld do and what gear chose)
Driving on 2nd gear and half way press accel.pedal won't go thru on 2nd gear ( shift up to 3th)
Again so sorry for my language is so dificul to explain all this things!! Im so like my is and 100% next car will be IS too!! Whatt is aprox cost of repair ( carbon build up issue ???)
Many thanks!!
What i can tell to dealer about carbon build up ???
Many thanks!!
Hi guys!!
Finaly i have my IS back from dealer!! ( not fix)
Dealer has no idea what can be wrong!! Workshop menager want me to pay for his guesses!! I ben told than he will replease some parts and check if this help!! If not he will replease another parts!!not give me any warranty that is correct guessl!! Firstly he want change my spark plugs ! I tell him spark plug was change 2 month ago but hi not listening!
For me is waste of many for parts witch can be in good condition!!!!
They want take many from me not fix the issue!!!
sjc2467
Apr 11, 2013 12:48 PM
grindin8o8
Mar 8, 2010 06:25 PM
Lexucan
15
Sep 15, 2007 02:14 PM
